@monsterfox Can you show a recording? Also what is the icon of the tool? (there are multiple different eraser tools).
And an example file (could be something with the shape).
It seems that clicking the eraser tool to erase the graphic isn't working.
I cannot replicate this, I need that file from the recording.
@VectorStyler https://youtu.be/hq_XGUYcn1g?feature=shared
When blending two graphics, in Freehand, you can select one of the graphics and then select "Parent" to choose the blended graphic. However, VS does not yet have this function, and we hope it can be added.
@monsterfox The problem here is that in VS the starting - blend - ending objects are 3 separate objects. They can be grouped, but that is a separate action.
Selecting the parent of one ending will not select the blend as it is not the parent.
@VectorStyler 0_1754664178907_重复效果.vstyler
In the operation process, I mostly use shortcut keys for most functions. When I open the Effects panel, I notice several duplicate effects, specifically the 4-point effect and the Transform effect. I'm not sure if this is by design, but at least the Transform effects should be mergeable.I had already applied the 4-point effect and added some other effects afterward. When I tried to continue using the 4-point effect via the shortcut key, it created a new instance instead of continuing the operation on the existing one, resulting in several duplicate effects. Is it possible to merge them?
Yes, this is by design, and these effects cannot be merged.
First: if you want to edit the existing 4-point effect, select it in the Shape Effects panel and click the second button in the panel button row.
Invoking menu commands will add a new effect, unless the selected effect is the last effect.
Why this is by design (even for transform): transforming an object with a 4-point effect is not the same that adding a 4-point effect to a transformed object (these are not commutative operations, the order cannot be exchanged).
There are only a few small sub-cases where the order could be exchanged (like a transform with uniform scaling only), but otherwise the order is important.
So if we have a "transform -> 4-point -> transform" sequence, the two transforms cannot be merged because that would mean changing the ordering.
1. Could we remove the secondary menu for "Miter" in the path offset function and replace it with the three function icons as shown in the image below? Miter is used quite frequently, and it's rather cumbersome to always have to click through the secondary menu to select it. Hope this can be addressed.
2. Could we add the color replacement function from the path offset dialog box to the path panel? The need for it in the panel is greater than in the dialog box, especially for replacing stroke colors. Hope this function can be added. Thank you.
This can be done.
I don't understand this. The Path panel does not work with fill or stroke. There is a Properties panel for this and the same in the Context panel.
@VectorStyler I have a specific need for the path color-changing function in the Paths panel, and I'm not sure if others have the same requirement. In my work, I need to offset some black lines in a graph by 1.5mm in a specified direction. There are too many paths, and the offset distance is small, so it's easy to make mistakes accidentally. Therefore, I need to change the color of the already offset paths as a mark. This operation needs to be applied to 9-21 such graphs. Since the quantity is large, I always try to optimize my workflow. I've also tried using actions to achieve this, which works, but it's cumbersome to switch back and forth between the operation interface and the panel. This Chinese software has the function of changing the color of the path after offsetting, and it can control the offset direction. When you click on the path with the mouse, you can see bidirectional arrows; just click in the corresponding opposite direction again to complete the operation. If possible, please add these two functions. At least add the function of changing the stroke color. Thank you.
https://youtu.be/faf_Rhnh-w4?feature=shared
@monsterfox This looks more like the Contour effect in VS with a single step.
The input box is too small.
I will fix this.
@VectorStyler https://youtu.be/5DpjF0Ld8vI?feature=shared
After editing the effect, the parameters cannot be modified; otherwise, it will revert to the unedited state. It is hoped that the parameters can be modified without disrupting the edited form.
This is a bit problematic. Changing the grid size will reset the mesh grid into its default state.
I will think of a solution.
@VectorStyler Cut a shape, create a new canvas, and paste the shape onto the canvas. However, the shape is not in the center of the canvas, and it is hoped that this issue can be optimized.
@monsterfox When pasting, the position on the new artboard is similar to the position on the original artboard, this is by design.
@VectorStyler I'm curious about maximizing the display of the current canvas. Theoretically, it should be in the center of the screen, and when we paste a graphic, it should also be in the center of the screen in theory, but there's a deviation. Most vector graphics software don't have this issue. Being able to paste graphics directly in the center of the canvas would save the subsequent steps of moving or aligning them to the center of the canvas. I still hope this problem can be resolved.
