  • @FastVector: yeah, my case is for removing the modifier. Why do we need it? Try Gimp once and see for yourself. It makes perfect sense to do the entire operation without any modifier whatsoever.
    The precedent for this was set by the ill conceived illustrator pen tool which splits two logically related, sequentially performed operation, creating curves and manipulating nodes.
    I'm recommending that we get rid of it the unnecessary modifier key.
    Double clicking adds a node.
    Middle clicking the node removes nodes. Simple. Clear. Economic.
  • @Daniel said in XLS for features and ideas - Megathread:
    Currently, clicking directly on an existing node adds a new node in the exact center of the path - this is a tool I'd not want to lose, though I could see adding a modifier to it since it's less commonly used than erasing a node
  • @Boldline
    ... clicking directly on an existing node adds a new node in the exact center of the path ...
    press the plus key "+" once does exact the same
  • @Boldline For me this is only working when I'm using the node tool and then I've to double click on a existing node. (I quess something different in my settings for the pen tool)
    @FastVector said in XLS for features and ideas - Megathread:
    Could be a settings issue. Send me your workspace/settings files (Help -> Reveal Workspace).
  • @FastVector
    Made a little Video here
    Using Ctrl+a while the Node Tool is selected
    will select all Nodes of a Shape.
  • How about single clicking curve to add a node. Double clicking a node to delete the node?
  • @Daniel
    A single click to add a node seems too risky to me, since its
    used to select a section of a path, and it's easy to click accidentally.
    And double-clicking a path to delete a node?
    I'm not really convinced.
    A modifier key to delete a node seems like a better solution
    in my eyes.
  • @Subpath
    Made a video of how the pen tool is working for me.
    The first part i'm just working with the pen tool without any keys.
    The second part I'm using the control key. It's for me not totally working the same as the node tool. By double clicking on a node I don't get a new node in the middle but it will go to the object isolation mode. And to delete a node I've to go to the context bar.
  • @FastVector
    i think i see it, adding a Node doesnt work when you
    activate the Node Tool with the Control Key.
    Your are right its the same here.
    Seems if you activate the Node Tool with the Control Key
    that the Node Tool its a bit limited then.
    Adding a Node works only by selecting the Node Tool
    direct.
  • Hey been away for while. I will continue here shortly. 🙂
  • Feature Idea: Fix alignment for selected objects. One of the most common steps that designers do is re-establish alignment after moving objects. So I was thinking there should be a way to fix alignment and distance between objects.
    For instance, if three Circles are selected and horizontally spaced and the distance between set to "100 pixels," moving one of the circles should re-establish alignment and distance. It should be of course possible to toggle off distance fix. Distance fixing is not a new idea. It already exists under the name of auto layouts in tools like Lunacy: https://blog.icons8.com/wp-content/uploads/2023/07/2-autolayout-settings.mp4
    But fixing alignments would be truly useful. It should also be possible to fix more than kind of alignment. For instance, horizontally spaced and aligned. In fact, if done correctly, it can work for entire groups of objects. We can call it aligned groups/alignment groups.
    Think of it like this: In the image below, you can fix make each line of objects, it's own alignment group. For instance, the red circles can be fixed for alignment across the centres and spaced vertically. And the first row of circles of different colours can fixed for alignment to the top edges and spaced horizontally. Now, moving any one object will keep the matrix structure intact. This is presently not possible in any apps.
    Importantly, it should be dynamic. Meaning, if I move the object, the others should move appropriately. https://imgbox.com/JJMryYn6 - I mean like this. But it does not fully capture what I mean. I should be able to move individual objects while retaining alignment across the whole group.
    @Daniel I added this to the backlog. It would be something like the auto layout from those apps.
  • Pigment Blend Gradient and L*, a*, b* colour gradients. Affinity now has a pigment blend option for gradient which allows you to simulate real pigment blending between colours. Although this might seem revolutionary, it has existed for at least a decade in PhotoLine through LAB colour gradients.
    Affinity's pigment blending
    PhotoLine's LAB Gradient:
    If I had to choose between the two, I'd choose LAB Gradient. Here's why. It is much more predictable in terms of resulting colour, and closer to how eye perceives real world colours. LAB includes 100% of the colours that the human eye can perceive, but arguably printers cannot reproduce. Screens can, depending on the colour gamut. It is so much more vivid.
    On the other hand, pigment blend is a really good idea. It simulates how colours actually mix. Blue and yellow produce green, rather than dirty brown. But this introduces a third colour into the mix. It is useful in artform scenarios definitely.
    Incidentally, and weirdly, Mesh Gradients cannot do pigment blending. A real and unnecessary oversight! It would have been quite useful to include pigment blending in Meshes as Meshes are more likely to simulate real light reflections. Oh well. Fragmentation is the biggest curse of Affinity.
    Ideally, we would have both. But I lean towards LAB. Community can vote.
    Edit:
    Here's the very real limitation of pigment blending: One of it has pigment blending on. But can you guess purely by looking at the image? You can't. The answer is: The one on the left has pigment blending ON. But it's negligible. But further below is a LAB gradient:
    See the difference?
    Also, PhotoLine is remarkably the only tool in existence today which allows you to set a colour from different colour spaces for each stop within the same gradient. You might think, ah so what? But when you're trying to simulate real world colours, this is not a small achievement. You can mix RGB, HIS, LAB, CMYK, and Tints of colours within the same gradient. This is a remarkable thing.
    They stole it from Xara, and you can steal it from them. Clicking those + signs adds new artboards on any side. It's quite nice. Xara has the same for individual objects within the artboard. Very rapidly allowing you to grid objects. As previously illustrated with the auto-layout options (see the gif in the comment on Alignment Fixing), Xara allows you to manage the space between these objects.
  • https://docs.astutegraphics.com/vectorscribe/vectorscribe-plugin-overview - This is one of my favourite plugins for Irritator. It is what Irritator should have aspired to be. There's so much here you can take. Planting it here, will come back and explain more.
    @Daniel Some of these things are also present in VectorStyler already
