<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Rounding the corners]]></title><description><![CDATA[<p dir="auto">Can we expect any improvements to this feature? It currently works randomly. Sometimes the handle is visible, elsewhere it is not, appear in unexpected places (e.g. on a path), sometimes clicking has no effect.<br />
<a href="https://recordit.co/NBE7tUxTmP" rel="nofollow ugc">https://recordit.co/NBE7tUxTmP</a><br />
I wonder if it would not be better to give up the function of rounding all corners at the same time and place a single rounding instead of. In my case, it often activates accidentally.  Personally, I prefer to select all corners with the Shift modifier. What is your opinion on this mechanic guys?<br />
A yellow outline appears when a single corner is selected. The problem is that it's not a clickable zone, a little blue center only.</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/712/rounding-the-corners</link><generator>RSS for Node</generator><lastBuildDate>Wed, 12 Aug 2026 14:20:17 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/712.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 01 Aug 2021 19:35:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Rounding the corners on Mon, 02 Aug 2021 18:05:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/encart" aria-label="Profile: encart">@<bdi>encart</bdi></a> Box selection of corners is an open issue (not always working right).<br />
I also managed to replicate the issue on Windows (Control+Click is not working).<br />
I will open a new bug around these corner issues.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/3410</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/3410</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 02 Aug 2021 18:05:06 GMT</pubDate></item><item><title><![CDATA[Reply to Rounding the corners on Mon, 02 Aug 2021 16:29:35 GMT]]></title><description><![CDATA[<p dir="auto">If the rounding has been made and we want to select this corner by dragging the cursor, we have to select all three points. It seems to me that only one would suffice. <a href="https://streamable.com/12z3cy" rel="nofollow ugc">https://streamable.com/12z3cy</a><br />
<img src="/forum/assets/uploads/files/1627921730930-screenshot_20210802_182513-resized.png" alt="0_1627921730212_screenshot_20210802_182513.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/3402</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/3402</guid><dc:creator><![CDATA[encart]]></dc:creator><pubDate>Mon, 02 Aug 2021 16:29:35 GMT</pubDate></item><item><title><![CDATA[Reply to Rounding the corners on Mon, 02 Aug 2021 16:18:46 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin  In my previous post in that thread I wrote some  suggestions for consideration.</p>
<li>
<p dir="auto">press + drag (no clicking) an not-selected corner, should modify all corners. This also means, that there is no selection.<br />
//<br />
IMHO that is the way how single corner should be edited.  I round individual corners more often than all at once  and wish to have  easy access, no unnecessary clicking and responsiveness,</p>
</li>
<li>
<p dir="auto">click on a corner, selects a single corner (indicated by orange circle).<br />
//<br />
Double click on any corner to select all</p>
</li>
<li>
<p dir="auto">Command+Click (Control+Click on Windows) selects additional corners*<br />
//<br />
This one doesn't work on my pc. Tried to perform with Shift/Control/Alt already.</p>
</li>
<p dir="auto">PS: Small active area of handles appears in shapes too.<br />
<a href="https://streamable.com/joexcz" rel="nofollow ugc">https://streamable.com/joexcz</a></p>
]]></description><link>https://www.vectorstyler.com/forum/post/3401</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/3401</guid><dc:creator><![CDATA[encart]]></dc:creator><pubDate>Mon, 02 Aug 2021 16:18:46 GMT</pubDate></item><item><title><![CDATA[Reply to Rounding the corners on Mon, 02 Aug 2021 05:43:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/encart" aria-label="Profile: encart">@<bdi>encart</bdi></a> Currently, the corner editor should work as follows:</p>
<li>press + drag (no clicking) an not-selected corner, should modify all corners. This also means, that there is no selection.</li>
<li>click on a corner, selects a single corner (indicated by orange circle).</li>
<li>Command+Click (Control+Click on Windows) selects additional corners</li>
<p dir="auto">Is this working (this way) for you?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/3336</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/3336</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 02 Aug 2021 05:43:46 GMT</pubDate></item><item><title><![CDATA[Reply to Rounding the corners on Mon, 02 Aug 2021 00:04:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/encart" aria-label="Profile: encart">@<bdi>encart</bdi></a> What you are proposing makes sense to me. I'm usually rounding one node - but there's a lot of value in being able to round all of them, or select ones at one time as well.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/3335</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/3335</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Mon, 02 Aug 2021 00:04:32 GMT</pubDate></item><item><title><![CDATA[Reply to Rounding the corners on Sun, 01 Aug 2021 22:54:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> When writing a post, as usual, I write from my own perspective. When I use rounding, I most often need to do this for a single point. For this reason, I believe that accessing this function should be the easiest and take  the place for current rounding multiple corners.</p>
<p dir="auto">Rounding single corner</p>
<li>direct click-and drag</li>
<p dir="auto">Rounding multiple corners</p>
<li>
<p dir="auto">Shift + click on each handle</p>
</li>
<li>
<p dir="auto">Shift + drag over handles ( i.e. selecting multiple corners  in two separate areas  of the object)</p>
</li>
<li>
<p dir="auto">Drag over handles</p>
</li>
<p dir="auto">Rounding all of the corners</p>
<li>
<p dir="auto">Double click on any of the nodes (like selecting whole words in text editor)</p>
</li>
<li>
<p dir="auto">Drag over the  object</p>
</li>
<p dir="auto">Or maybe  double click on  each handle could reset the rounding?</p>
<p dir="auto">Edit:<br />
I'm not sure if it's only my problem, but  quick select single handle and drag has no effect. <a href="https://recordit.co/Jwq5nWvVir" rel="nofollow ugc">Video</a></p>
]]></description><link>https://www.vectorstyler.com/forum/post/3334</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/3334</guid><dc:creator><![CDATA[encart]]></dc:creator><pubDate>Sun, 01 Aug 2021 22:54:00 GMT</pubDate></item><item><title><![CDATA[Reply to Rounding the corners on Sun, 01 Aug 2021 20:34:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> said in <a href="/forum/post/3332">Rounding the corners</a>:</p>
<blockquote>
<p dir="auto">What indeed can be a bit confusing is that Shift-click to select multiple rounding handles doesn't do anything. Maybe it should?</p>
</blockquote>
<p dir="auto">I agree that a shift and click on individual nodes should select specific nodes to round the corners with -</p>
]]></description><link>https://www.vectorstyler.com/forum/post/3333</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/3333</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Sun, 01 Aug 2021 20:34:25 GMT</pubDate></item><item><title><![CDATA[Reply to Rounding the corners on Sun, 01 Aug 2021 20:32:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/encart" aria-label="Profile: encart">@<bdi>encart</bdi></a> The rounding handle will overlap a path when the other segment connected to its node is not straight — in this case it probably has a Bézier handle that is very close to that node, and it bends the segment just a bit.</p>
<p dir="auto">Anyway, multiple rounding handles can be selected with…</p>
<li>direct click-and-drag (box select over multiple handles). and with…</li>
<li>Shift + click-and-drag over each handle.</li>
]]></description><link>https://www.vectorstyler.com/forum/post/3332</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/3332</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Sun, 01 Aug 2021 20:32:23 GMT</pubDate></item></channel></rss>
