<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[One-Command Print Preview Toggle with Print Profile]]></title><description><![CDATA[<p dir="auto">It would be very helpful to have a feature that toggles a print preview with the print profile applied (and returns to the previous working state) using a single command from the active workspace.<br />
I go back and forth between checking the preview and returning to my work many times during production, which is currently cumbersome. I would appreciate it if you could consider this.</p>
<p dir="auto">Currently, to check how the final print will look, it is necessary to turn off various working aids and guides (the specific items that need to be turned off vary depending on each user's workspace setup).<br />
In my case, I repeatedly switch through the following steps:</p>
<ol>
<li>Show Artboard Margins: Off (context menu)</li>
<li>Show Guidelines: Off (context menu)</li>
<li>Show Hidden Characters: Off (context menu)</li>
<li>Switch to Single Document View (registering this in the context menu causes a crash)</li>
<li>Full Screen (shortcut)</li>
<li>Fit Artwork to Screen (manual)</li>
</ol>
]]></description><link>https://www.vectorstyler.com/forum/topic/5998/one-command-print-preview-toggle-with-print-profile</link><generator>RSS for Node</generator><lastBuildDate>Sat, 28 Nov 2026 04:56:27 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5998.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 27 Nov 2026 01:37:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to One-Command Print Preview Toggle with Print Profile on Fri, 27 Nov 2026 01:43:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/861475_vctst" aria-label="Profile: 861475_VctSt">@<bdi>861475_VctSt</bdi></a> I added this to the feature backlog</p>
]]></description><link>https://www.vectorstyler.com/forum/post/34525</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/34525</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 27 Nov 2026 01:43:09 GMT</pubDate></item></channel></rss>
