<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Prevent accidental renaming in the Layers panel]]></title><description><![CDATA[<p dir="auto">I use double-click both in the Layers panel to rename objects and on the artboard to work with my artwork. I want to keep both workflows. The problem is that an object name can change before I’ve deliberately opened it for editing.</p>
<p dir="auto">For example, I likely pressed ⌘V to paste artwork while the Layers panel still had focus. The selected path ended up named &lt;?xml version="1.0" …. It looks like VectorStyler pasted the raw SVG text from my clipboard into the path’s name.</p>
<p dir="auto">Could ⌘V change an object name only when the name field is open for editing? That would let me keep double-clicking to rename while preventing an ordinary paste from overwriting a name.</p>
<p dir="auto">UPDATE: I found that enabling Object Pasteboard in the Layers panel options prevents one kind of accidental rename. When the Layers panel has focus and I press ⌘V, VectorStyler uses the clipboard for pasting objects. With the option off, it can apply clipboard text, such as an SVG title, to the selected layer or object name.</p>
<p dir="auto">My remaining request is for a setting to disable inline renaming when I click an already selected name. I often click the row again just to select the object.</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1795721873578-2fa1d112-fca2-4f81-9646-d58047410512-cleanshot-2026-11-26-at-2.35.57-pm.png" alt="2fa1d112-fca2-4f81-9646-d58047410512-CleanShot 2026-11-26 at 2.35.57 PM.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5997/prevent-accidental-renaming-in-the-layers-panel</link><generator>RSS for Node</generator><lastBuildDate>Sat, 28 Nov 2026 04:56:15 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5997.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 26 Nov 2026 19:39:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Prevent accidental renaming in the Layers panel on Fri, 27 Nov 2026 01:09:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> I opened a bug on this.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/34522</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/34522</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 27 Nov 2026 01:09:11 GMT</pubDate></item></channel></rss>
