<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Elastic Warp: Freeze selected areas and move multiple pins together]]></title><description><![CDATA[<p dir="auto">I’d like to request three improvements to the Elastic Warp tool:</p>
<ol>
<li>
<p dir="auto">Freeze an area with a lasso. Allow the user to draw a freehand selection around part of the artwork and freeze everything inside it. The frozen area should stay in place and retain its shape while I drag pins elsewhere. For example, I could freeze a basketball rim and the top of the net (area marked #2 in green rectangle in ref image), then pull the bottom of the net down and to the left (area marked #1 in red circle in ref image). I’d also like a visible overlay while editing and a Clear Freeze command.</p>
</li>
<li>
<p dir="auto">Select and move multiple pins together. Let me Shift-click or marquee-select several pins, then drag any selected pin to move the entire selection by the same amount. For example, I could select three pins across the bottom of the net and move them together while keeping their spacing. Unselected pins would stay where they were placed.</p>
</li>
<li>
<p dir="auto">Add a Show Warp Mesh toggle. Vectorcraft &amp; Illustrator have a triangular mesh overlay that makes it easier to see where a warp stretches or compresses the artwork. A Show Warp Mesh toggle in the Elastic Warp toolbar would let me see the mesh update live as I move pins, then hide it to inspect the artwork cleanly. <em>UPDATE -found mesh toggle in Elastic Warp options in Shape Effects panel</em></p>
</li>
</ol>
<p dir="auto"><img src="/forum/assets/uploads/files/1795717752853-802bcac9-59a9-48bf-bb55-04e2b7136031-cleanshot-2026-11-26-at-1.27.08-pm.png" alt="802bcac9-59a9-48bf-bb55-04e2b7136031-CleanShot 2026-11-26 at 1.27.08 PM.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Example of triangular mesh overlay:<br />
<img src="/forum/assets/uploads/files/1795718205619-d4da4943-4471-44a9-b6e6-2b5bda28a598-cleanshot-2026-11-26-at-1.33.53-pm.png" alt="d4da4943-4471-44a9-b6e6-2b5bda28a598-CleanShot 2026-11-26 at 1.33.53 PM.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Rough example of what lasso tool freeze could look like:<br />
<img src="/forum/assets/uploads/files/1795718504240-a432b9ba-c4f8-4bf2-be87-6d202e155827-cleanshot-2026-11-26-at-1.41.06-pm.png" alt="a432b9ba-c4f8-4bf2-be87-6d202e155827-CleanShot 2026-11-26 at 1.41.06 PM.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5996/elastic-warp-freeze-selected-areas-and-move-multiple-pins-together</link><generator>RSS for Node</generator><lastBuildDate>Sat, 28 Nov 2026 04:56:18 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5996.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 26 Nov 2026 18:32:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Elastic Warp: Freeze selected areas and move multiple pins together on Fri, 27 Nov 2026 01:10:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> I will think of a solution for this, not sure yet if possible.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/34523</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/34523</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 27 Nov 2026 01:10:56 GMT</pubDate></item></channel></rss>
