<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Preserving and migrating settings across major updates (and risks of importing .settings &#x2F; .vstool files)]]></title><description><![CDATA[<p dir="auto">When updating from <a href="http://1.3.xxx" rel="nofollow ugc">1.3.xxx</a> to 1.4.001, I encountered a series of baffling issues that I had never experienced before. On the surface, print-related markers (such as printer marks) stopped displaying, and 100% Black (K100) began appearing like rich black.</p>
<p dir="auto">To resolve this, I completely removed all VectorStyler-related data and performed a clean installation. Afterward, to restore my workspace, I tried the following methods separately as independent approaches:</p>
<li>Importing previously exported configuration files (such as .settings, .vstool, and .vswork).</li>
<li>Restoring data from a backup of my Application Support folder.</li>
<p dir="auto">However, neither method solved the issue—likely because the backups themselves already contained corrupted or incompatible resources. In the process of troubleshooting, I even reached a point where I could no longer switch the UI language to Japanese.</p>
<p dir="auto">With no other options left, I ended up rebuilding all my preferences and tool setups manually from scratch on a clean installation. Since this process is quite time-consuming, I would like to avoid having to repeat it in the future.</p>
<p dir="auto">To prevent this kind of situation going forward, could you advise on the following?</p>
<ol>
<li>Best practices for updates: What is the safest procedure before or after an update to prevent settings corruption or resource conflicts?</li>
<li>Compatibility of exported files: Is it risky to import .settings, .vstool, or .vswork files across major version updates? Specifically, when an update changes the menu structure, icon sets, or internal specifications, can loading older configuration files directly cause regressions or UI glitches?</li>
</ol>
]]></description><link>https://www.vectorstyler.com/forum/topic/5989/preserving-and-migrating-settings-across-major-updates-and-risks-of-importing-.settings-.vstool-files</link><generator>RSS for Node</generator><lastBuildDate>Wed, 25 Nov 2026 04:20:15 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5989.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 25 Nov 2026 02:49:32 GMT</pubDate><ttl>60</ttl></channel></rss>
