<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.4.001]]></title><description><![CDATA[<h3>VectorStyler 1.4.001 release notes</h3>
<li>Added a new smooth curvature tool</li>
<li>Added multiple new path brush tools</li>
<li>Added margin constraint options to the Transform tool</li>
<li>Erase using custom shapes</li>
<li>Improved the Arc tool</li>
<li>Added optical alignment options</li>
<li>Added an optical snapping option to the snapping menu</li>
<li>Position objects using their optical axes in the Transform panel</li>
<li>Added Truchet tiling shape type and Truchet pattern presets</li>
<li>Added a halftone type that uses Truchet patterns to simulate the backdrop</li>
<li>Added a new Width Halftone shape using Truchet tiling shapes</li>
<li>New repeater geometry mode (for Truchet tiles)</li>
<li>New tiling pattern mode for more complex tiles (used for Truchet tiles)</li>
<li>Added freeform gradients</li>
<li>Action to remove opacity from objects inside selected groups</li>
<li>Hierarchical object styling using groups and shapeless objects</li>
<li>Added a document option for expanded stroke precision</li>
<li>Allow pattern brushes to extend beyond the start and end of a path</li>
<li>Show a curvature indicator while editing paths, using an option in the Path panel menu</li>
<li>Added a node type that maintains G2 continuity</li>
<li>Add curvature smoothing option to the pencil and path simplifying tools</li>
<li>Select path nodes with G2 discontinuity</li>
<li>Change path nodes to G2 continuity</li>
<li>Select multiple consecutive nodes using Shift+Control</li>
<li>Drag segments from interior points using Command (Control) key</li>
<li>Move a node between its control points by holding Option (Alt)</li>
<li>Scale selected control points around a common center by holding the Option (Alt) key</li>
<li>Trace guide tool improvements</li>
<li>Added a command to expand a clipped group into connected shapes (Extract Clipped Paths)</li>
<li>Added an option to keep original shapes when combining (in Path panel menu Shape Combine Options)</li>
<li>Divide shapes with open paths</li>
<li>Added an option to Mirror and Transform groups to merge shapes when expanding</li>
<li>Action to flatten curves to lines if they are almost flat</li>
<li>Added a shape effect for smoothing curvature</li>
<li>Combine multiple repeater geometry adjustments on a single repeater</li>
<li>Option to place objects at segment centers in Along Path repeater mode</li>
<li>Repeater colorizer option to align positions with region</li>
<li>Proportional mode for repeater extent editing</li>
<li>Action to rotate the view to the angle of the selection</li>
<li>Added printing marks when exporting to PDF or PS</li>
<li>Swap fill and stroke styles from the context panel</li>
<li>Restrict font list to a specific script</li>
<li>New command to apply the reverse of the last transform operation</li>
<li>Create groups containing a single object to stack styles and effects</li>
<li>Option to allow duplicate on other objects to repeat previous transform: <em>Clear Transform on Selection</em> in <em>Other Options</em></li>
<li>Overprint preview in both CPU and GPU views</li>
<p dir="auto">Detailed list at: <a href="https://www.vectorstyler.com/documentation/introduction/newin_v1_4/" rel="nofollow ugc">https://www.vectorstyler.com/documentation/introduction/newin_v1_4/</a></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5981/update-1.4.001</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 01:41:23 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5981.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 20 Nov 2026 15:06:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.4.001 on Sun, 22 Nov 2026 00:53:46 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for releasing Ver. 1.4.001.</p>
<p dir="auto">Since these issues affect my daily workflow, I am sending a quick report regarding two regressions of basic features that were previously fixed:</p>
<ol>
<li>Printing-related regression: Printer marks (trim marks, etc.) are not displayed.<br />
The issue previously discussed in the following topic has recurred:<br />
<a href="https://www.vectorstyler.com/forum/topic/655/printer-mark-does-not-work-properly-continued/8">https://www.vectorstyler.com/forum/topic/655/printer-mark-does-not-work-properly-continued/8</a></li>
<li>Black display regression in the panel: Incorrect display of Black.<br />
The indicator and default display issues previously reported in the following topics have recurred:<br />
<a href="https://www.vectorstyler.com/forum/topic/3506/about-the-black-defaults-for-each-color-mode">https://www.vectorstyler.com/forum/topic/3506/about-the-black-defaults-for-each-color-mode</a><br />
<a href="https://www.vectorstyler.com/forum/topic/4797/text-color-indicator/15">https://www.vectorstyler.com/forum/topic/4797/text-color-indicator/15</a></li>
</ol>
<p dir="auto">This is just a quick initial report, and I would appreciate it if you could look into these issues.</p>
<p dir="auto">Best regards,</p>
]]></description><link>https://www.vectorstyler.com/forum/post/34458</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/34458</guid><dc:creator><![CDATA[861475_VctSt]]></dc:creator><pubDate>Sun, 22 Nov 2026 00:53:46 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.4.001 on Sat, 21 Nov 2026 20:59:17 GMT]]></title><description><![CDATA[<p dir="auto">Will check this out ASAP</p>
]]></description><link>https://www.vectorstyler.com/forum/post/34455</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/34455</guid><dc:creator><![CDATA[debraspicher]]></dc:creator><pubDate>Sat, 21 Nov 2026 20:59:17 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.4.001 on Sat, 21 Nov 2026 07:19:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/861475_vctst" aria-label="Profile: 861475_VctSt">@<bdi>861475_VctSt</bdi></a> said in <a href="/forum/post/34439">update 1.4.001</a>:</p>
<blockquote>
<p dir="auto">I have noticed a few regressions,</p>
</blockquote>
<p dir="auto">Let me know as soon as possible.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/34442</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/34442</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sat, 21 Nov 2026 07:19:08 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.4.001 on Sat, 21 Nov 2026 04:26:59 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for the new update (1.4.001)!</p>
<p dir="auto">Since 1.3.001 was released on November 18, I had a hunch that a new major version might be coming around this time. However, unlike the previous release, there was no beta version beforehand, so I thought it might still be a little further off.</p>
<p dir="auto">I have noticed a few regressions, so I will thoroughly test everything within my usual workflow first and report back to you once I have organized the details.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/34439</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/34439</guid><dc:creator><![CDATA[861475_VctSt]]></dc:creator><pubDate>Sat, 21 Nov 2026 04:26:59 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.4.001 on Fri, 20 Nov 2026 19:26:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> This is really exciting! Thank you for all your hard work improving VS and doing so much extra behind the scenes to make the new 1.4 version so impressive! I am looking forward to checking out all of the new features and improvements. I prefer VS over any other vector editing software available today</p>
]]></description><link>https://www.vectorstyler.com/forum/post/34437</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/34437</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Fri, 20 Nov 2026 19:26:20 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.4.001 on Fri, 20 Nov 2026 16:08:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/subpath" aria-label="Profile: Subpath">@<bdi>Subpath</bdi></a> said in <a href="/forum/post/34435">update 1.4.001</a>:</p>
<blockquote>
<p dir="auto">During installation, VectorStyler displays version 1.3; the name of the icon is also 1.3.</p>
</blockquote>
<p dir="auto">Thanks! Should be fixed now.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/34436</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/34436</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 20 Nov 2026 16:08:25 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.4.001 on Fri, 20 Nov 2026 15:54:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a></p>
<p dir="auto">Forgot, there is a minor thing.<br />
During installation, VectorStyler displays version 1.3; the name of the icon is also 1.3.<br />
But the installed App is 1.4</p>
]]></description><link>https://www.vectorstyler.com/forum/post/34435</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/34435</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Fri, 20 Nov 2026 15:54:59 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.4.001 on Fri, 20 Nov 2026 15:44:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a></p>
<p dir="auto">WOW !!!</p>
<p dir="auto">This feels like a really big Christmas present—and sorry, but I’ll probably end up opening it before Christmas.<br />
​​Once again, I am truly impressed!</p>
<p dir="auto">Thank you for your hard Work<br />
Vectorstyler <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--+1" style="height:23px;width:auto;vertical-align:middle" title=":+1:" alt="👍" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/34434</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/34434</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Fri, 20 Nov 2026 15:44:42 GMT</pubDate></item></channel></rss>
