<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Make Locked Objects Selectable Only When Needed]]></title><description><![CDATA[<p dir="auto">I’d like a quicker way to switch between two behaviors for locked objects in VectorStyler:</p>
<li><strong>Ignore locked objects.</strong> Clicking or dragging a selection box skips locked artwork, so I can see exactly what’s editable.</li>
<li><strong>Allow selection of locked objects.</strong> I can click a specific locked object and choose <strong>Unlock</strong>. The object stays protected from edits until I unlock it.</li>
<p dir="auto">Right now, <strong>Select → Options → Allow Locked Objects</strong> makes it easy to pick an object to unlock, but it also brings locked artwork into my everyday selections. That makes it harder to tell at a glance which objects I can edit.</p>
<p dir="auto">Could we have either a <strong>keyboard modifier</strong> I can hold while clicking to temporarily target a locked object, or <strong>two radio options in the canvas context menu</strong> so I can quickly switch between <strong>Ignore Locked Objects</strong> and <strong>Allow Locked Object Selection</strong>?</p>
<p dir="auto">My preference is the modifier. I could hold it, click the one object I want to unlock, then release it and go straight back to working with unlocked artwork.</p>
<p dir="auto"><a href="https://www.vectorstyler.com/forum/topic/5935/add-unlock-to-the-right-click-menu-for-locked-objects">Earlier discussion about adding Unlock to the context menu</a></p>
<p dir="auto"><img src="/forum/assets/uploads/files/1794186205722-37f2a6ea-c079-4d2e-a6f0-6314503abce5-cleanshot-2026-11-08-at-7.36.12-pm.png" alt="37f2a6ea-c079-4d2e-a6f0-6314503abce5-CleanShot 2026-11-08 at 7.36.12 PM.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5972/make-locked-objects-selectable-only-when-needed</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Nov 2026 21:15:00 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5972.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 09 Nov 2026 01:02:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Make Locked Objects Selectable Only When Needed on Mon, 09 Nov 2026 05:04:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> I will think of a solution.</p>
<p dir="auto">Should this work in the default Transform tool or in other tools also (like the Node tool)?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/34393</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/34393</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 09 Nov 2026 05:04:50 GMT</pubDate></item></channel></rss>
