<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Optional Shape Diagnostics Before and After Boolean Operations]]></title><description><![CDATA[<p dir="auto">When using Merge, Unite, Expand, or other shape operations in VectorStyler, I occasionally encounter unexpected results where objects or portions of objects disappear.</p>
<p dir="auto">The frustrating part is not knowing why this happens. I can't tell whether VectorStyler produced a mathematically valid result based on the geometry, encountered a condition it couldn't process correctly, or experienced an actual bug.</p>
<p dir="auto">I usually end up trying several different fixes until something works. This becomes a trial-and-error process without understanding the cause.</p>
<p dir="auto"><a href="https://cleanshot.com/share/yxH7p0kd" rel="nofollow ugc">Here is a video showing how there was an unexpected result at first and part of the vectors on screen disappeared.</a></p>
<p dir="auto">Would it be technically feasible to introduce an optional diagnostic command that analyzes shapes both before and after an operation?</p>
<p dir="auto"><strong>Before an operation</strong></p>
<p dir="auto">I could select one or more objects and run a command such as "Shape Diagnostics" to identify potential problems before applying Merge, Unite, Expand, or another operation.</p>
<p dir="auto">For example, it could check for:</p>
<p dir="auto">Open paths or self-intersections</p>
<p dir="auto">Duplicate or overlapping paths</p>
<p dir="auto">Multiple fills or strokes that might affect the operation</p>
<p dir="auto">Compound paths or complex appearances</p>
<p dir="auto">Other geometric conditions that could produce unexpected results</p>
<p dir="auto">Ideally, VectorStyler would highlight the affected objects or paths, explain the potential issue, and suggest a correction.</p>
<p dir="auto"><strong>After an operation</strong></p>
<p dir="auto">If an operation produces an unexpected result, I could run the diagnostic command to investigate what happened.</p>
<p dir="auto">Ideally, it could distinguish between:</p>
<p dir="auto">A mathematically valid result that may not match the user's expectations</p>
<p dir="auto">A known geometry or appearance condition that affected the result</p>
<p dir="auto">An operation that encountered a processing error</p>
<p dir="auto">It would be particularly useful if VectorStyler could identify which objects or regions were removed or altered and explain the likely reason.</p>
<p dir="auto"><strong>An existing example from the VectorStyler forum</strong></p>
<p dir="auto">A good example of why this feature would be useful is the discussion:</p>
<p dir="auto">Merge operation deletes the object underneath</p>
<p dir="auto">In that report, the Merge operation unexpectedly deleted the lower object instead of producing the expected result.</p>
<p dir="auto">The developer confirmed that the behavior was a bug and later identified the cause: the blue object contained two blue fills, which the operation was not handling correctly.</p>
<p dir="auto">The suggested workaround was to remove one of the fills in the Appearance panel before applying Merge.</p>
<p dir="auto">This illustrates exactly the kind of problem I'm describing.</p>
<p dir="auto">Without the developer's explanation, a user might spend considerable time modifying paths, changing object order, or experimenting with other settings without realizing that the additional fill was responsible.</p>
<p dir="auto">An optional diagnostic command that could identify a condition like this would make troubleshooting considerably easier.</p>
<p dir="auto"><strong>Optional rather than automatic</strong></p>
<p dir="auto">I would prefer diagnostics to be available on demand rather than having warnings interrupt normal operations.</p>
<p dir="auto">I'm not suggesting that VectorStyler should predict the user's intended result. I'm asking whether the application could expose information about the geometry and processing conditions that influence the outcome.</p>
<p dir="auto">The goal is to eliminate the guesswork. Instead of repeatedly experimenting with different fixes, users could identify potential problems beforehand or investigate unexpected results afterward.</p>
<p dir="auto">Even a basic diagnostic report that identifies problematic objects and suggests possible corrections would be valuable.</p>
<p dir="auto">Is this something VectorStyler's current geometry engine could realistically support?</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5965/optional-shape-diagnostics-before-and-after-boolean-operations</link><generator>RSS for Node</generator><lastBuildDate>Sat, 31 Oct 2026 17:13:41 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5965.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 31 Oct 2026 02:41:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Optional Shape Diagnostics Before and After Boolean Operations on Sat, 31 Oct 2026 06:59:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> I will try to add this as soon as possible.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/34322</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/34322</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sat, 31 Oct 2026 06:59:47 GMT</pubDate></item></channel></rss>
