<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Batch Export Layers Using Canvas or Artboard Bounds]]></title><description><![CDATA[<p dir="auto">VectorStyler's Object Export feature already allows individual layers to be exported as separate PNG files, which is extremely useful.</p>
<p dir="auto">However, when exporting multiple layers that need identical dimensions and alignment, the current workaround is to add an invisible, full-canvas rectangle to each layer.</p>
<p dir="auto">Would it be possible to eliminate this requirement by adding an <strong>Export Bounds</strong> option to the Object Export settings?</p>
<p dir="auto">For example:</p>
<li><strong>Object Bounds:</strong> Export using the actual dimensions of the selected layer or object (current behavior).</li>
<li><strong>Canvas Bounds:</strong> Export each selected layer using the full canvas dimensions.</li>
<li><strong>Artboard Bounds:</strong> Export each selected layer using the corresponding artboard dimensions.</li>
<p dir="auto">With Canvas Bounds or Artboard Bounds selected, every exported PNG would have identical dimensions, with the artwork retaining its original position and transparent pixels filling the unused areas.</p>
<p dir="auto">This would be especially useful for screen printing, where individual color separation layers need to maintain exact alignment when exported as PNG files.</p>
<p dir="auto">It would also simplify the workflow considerably, allowing users to select multiple layers and export them all in one operation without adding invisible rectangles.</p>
<p dir="auto">Is this something that could be added to the Object Export feature?</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5944/batch-export-layers-using-canvas-or-artboard-bounds</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 01:33:12 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5944.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 11 Oct 2026 19:58:13 GMT</pubDate><ttl>60</ttl></channel></rss>
