<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.3.028]]></title><description><![CDATA[<h3>VectorStyler 1.3.028 release notes</h3>
<li>Improved exclude operation of shapes of images with stroke attributes</li>
<li>In Glyphs panel show the actual character code from the selected string</li>
<li>Select halftone options with halftone tool double ckicks</li>
<li>Drag and Drop import to place on canvas by default</li>
<li>Added option (in settings) to import images using the current document resolution</li>
<li>Always place text frame link knobs on the selection boundary</li>
<li>Improved line breaking rules inside text frames</li>
<li>Improved search in font lists</li>
<li>Option to include bleed area into the page fill</li>
<li>Added overprint options to character style settings</li>
<li>Added extra info to the missing file notification</li>
<li>Indicate in settings preset name if settings was changed</li>
<li>Default colors in document options should use the document color mode</li>
<li>Open newly created image and shape effect options if Open in List option is enabled</li>
<li>Fixed a pattern isolation bug</li>
<li>Fixed a bug in selecting gradient fill in the contour effect</li>
<li>Fixed a crash in the mesh and envelope effect editors</li>
<li>Fixed a bug in text formatting with a tab character at the last position</li>
<li>Fixed a bug in exporting spot colors to EPS file format</li>
<li>Fixed a bug in concentric repeater Insert at Center option</li>
<li>Fixed a bug in text stretching and alignment</li>
<li>Fixed a bug in repeaters containing expanded stroke effects</li>
<li>Fixed a bug in selecting the Transformed Pattern option from the tiling pattern popup view</li>
<li>Fixed a bug in the Expanded Stroke adjustment effect</li>
<li>Fixed a bug in expanding clipped groups</li>
<li>Fixed a bug with Pen tool lag when clicking</li>
<li>Fixed an OpenType variable font bug</li>
<li>Fixed a file naming issue in Export Again</li>
<li>Fixed a bug in the flipping action from the context panel</li>
<li>Fixed an issue when selecting stroke color on the image object</li>
<li>Fixed a bug in exporting text frames with image effects into PDF</li>
<li>Fixed a bug in exporting transparency into PDF</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/5932/update-1.3.028</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 13:03:45 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5932.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 06 Oct 2026 15:46:43 GMT</pubDate><ttl>60</ttl></channel></rss>
