<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Flip Horizontally shortcut tool creates copy when copy modifier is not used]]></title><description><![CDATA[<p dir="auto"><a href="https://cleanshot.com/share/5Y9LfS3Z" rel="nofollow ugc">Here is a link to an example of where using the horizontal reflect tool creates a duplicate instead of just flipping the object itself.</a></p>
<p dir="auto"><strong>I think this is related to my settings files, because when I switched back to default settings, the issue disappeared. I switched back to my custom settings and the issue is not happening there either. I wonder if there is a setting that was adjusted but not saved to the custom file that caused the issue?</strong></p>
<p dir="auto">I added the VS file to this post - at the bottom</p>
<p dir="auto">The history is recording it as a "Flip Horizontally with Copy", even though I am not using the alt/option modifier at all.</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1790719887050-d34c3194-8a4b-41f8-ab0d-ead7d836974b-cleanshot-2026-09-29-at-6.11.06-pm.png" alt="d34c3194-8a4b-41f8-ab0d-ead7d836974b-CleanShot 2026-09-29 at 6.11.06 PM.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><a href="/forum/assets/uploads/files/1790720025832-horizontal-flip-with-copy-issue.vstyler">Horizontal  flip with copy issue.vstyler</a></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5930/flip-horizontally-shortcut-tool-creates-copy-when-copy-modifier-is-not-used</link><generator>RSS for Node</generator><lastBuildDate>Thu, 01 Oct 2026 12:33:24 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5930.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 29 Sep 2026 22:14:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Flip Horizontally shortcut tool creates copy when copy modifier is not used on Wed, 30 Sep 2026 17:23:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> I just emailed you the settings files. Since switching to the default settings and then reloading my saved custom settings, I haven’t been able to reproduce the issue. It’s possible I had made an unsaved change to the custom settings, which was lost when I switched presets.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33985</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33985</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Wed, 30 Sep 2026 17:23:57 GMT</pubDate></item><item><title><![CDATA[Reply to Flip Horizontally shortcut tool creates copy when copy modifier is not used on Wed, 30 Sep 2026 04:44:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> Do you still have the settings / workspace where this occurs?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33984</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33984</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 30 Sep 2026 04:44:28 GMT</pubDate></item></channel></rss>
