<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Repeater, be able to link values together]]></title><description><![CDATA[<p dir="auto">One thing I miss every time I use the repeater—and I don't<br />
understand why this isn't possible yet.</p>
<p dir="auto">Is the ability to link these values ​​together so they can both be changed at once.<br />
In the repeater, you always have to change each value individually, even when<br />
you actually want to change both simultaneously.<br />
.<br />
.<br />
<img src="/forum/assets/uploads/files/1789973548527-ksnip_20260921-084230.png" alt="ksnip_20260921-084230.png" class=" img-fluid img-markdown" /><br />
.<br />
.<br />
<img src="/forum/assets/uploads/files/1789973762400-ksnip_20260921-084326.png" alt="ksnip_20260921-084326.png" class=" img-fluid img-markdown" /><br />
.<br />
.<br />
.<br />
A solution like this would be fine</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1789973600006-ksnip_20260921-084621.png" alt="ksnip_20260921-084621.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5924/repeater-be-able-to-link-values-together</link><generator>RSS for Node</generator><lastBuildDate>Tue, 22 Sep 2026 11:30:16 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5924.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 21 Sep 2026 06:53:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Repeater, be able to link values together on Tue, 22 Sep 2026 06:54:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Yes,That makes more sense. If identical parameters are required, fill in the same values in both fields and then lock the ratio for easier operation.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33962</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33962</guid><dc:creator><![CDATA[monsterfox]]></dc:creator><pubDate>Tue, 22 Sep 2026 06:54:07 GMT</pubDate></item><item><title><![CDATA[Reply to Repeater, be able to link values together on Tue, 22 Sep 2026 04:21:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/monsterfox" aria-label="Profile: monsterfox">@<bdi>monsterfox</bdi></a> said in <a href="/forum/post/33959">Repeater, be able to link values together</a>:</p>
<blockquote>
<p dir="auto">My idea: can we add a lock before performing parameter‑setting operations.</p>
</blockquote>
<p dir="auto">Would this be a sort of locking the current ratio, as in the Transform panel ?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33961</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33961</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 22 Sep 2026 04:21:52 GMT</pubDate></item><item><title><![CDATA[Reply to Repeater, be able to link values together on Tue, 22 Sep 2026 03:44:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a><br />
There are two scenarios:</p>
<ol>
<li>Interval ratio of the current value</li>
<li>Ratio for equal‑value cases</li>
</ol>
]]></description><link>https://www.vectorstyler.com/forum/post/33959</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33959</guid><dc:creator><![CDATA[monsterfox]]></dc:creator><pubDate>Tue, 22 Sep 2026 03:44:37 GMT</pubDate></item><item><title><![CDATA[Reply to Repeater, be able to link values together on Mon, 21 Sep 2026 19:44:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> said in <a href="/forum/post/33956">Repeater, be able to link values together</a>:</p>
<blockquote>
<p dir="auto">I chalk it up to Csaba being a solo developer doing a ton of tools and features and updates at record speed and some things happen to fall through the cracks and have to be addressed as they are found by the users. but that does not make your criticism any less valid. Many workflow issues only become obvious once a feature is used frequently.</p>
</blockquote>
<p dir="auto">I don't view this as criticism at all; I'm just mentioning what stands out to me.</p>
<p dir="auto">I know the dev has a lot on his plate, and I'm totally relaxed about it. There's no<br />
need for the dev to stress himself out over this; he should definitely take whatever<br />
time he needs. At least from my perspective.</p>
<p dir="auto">However, I do think that some form of standardization will be due again at some point.<br />
After all, it also helps keep VectorStyler attractive to new users.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33957</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33957</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Mon, 21 Sep 2026 19:44:35 GMT</pubDate></item><item><title><![CDATA[Reply to Repeater, be able to link values together on Mon, 21 Sep 2026 16:45:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/subpath" aria-label="Profile: Subpath">@<bdi>Subpath</bdi></a> I understand you completely on that. Looking at the panels as a whole and bringing similar controls up to the same standard would be better than addressing the Repeater alone. If values represent two dimensions of the same setting, users should be able to link them wherever that behavior makes sense.</p>
<p dir="auto">There's a long list of improvements and ideas we've collectively shared with him over the years and he keeps adding them into VS as he can. If they're not already planned for and/or included already in the 1.4 update to come, I'm sure we can address them again.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33956</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33956</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Mon, 21 Sep 2026 16:45:44 GMT</pubDate></item><item><title><![CDATA[Reply to Repeater, be able to link values together on Mon, 21 Sep 2026 16:26:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a></p>
<p dir="auto">Well, I would actually say that this is long overdue. After all, why are there<br />
panels where you can link values, yet panels like the Repeater—with its<br />
extensive set of values—where that isn't possible? In that regard, it seems<br />
stuck in the past to me.</p>
<p dir="auto">It probably wouldn't hurt to take a general look at which panels could—so to<br />
speak—be brought up to the same standard.</p>
<p dir="auto">Since I used to use the repeater only occasionally, I did notice this issue but<br />
ignored it as best I could. It was only recently, when I started using the repeater<br />
more frequently for my color experiments, that I found it increasingly bothersome.</p>
<p dir="auto">It often takes a while for a user to speak up, after all, because unfortunately, one<br />
often only notices such things when using a feature more frequently.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33955</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33955</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Mon, 21 Sep 2026 16:26:22 GMT</pubDate></item><item><title><![CDATA[Reply to Repeater, be able to link values together on Mon, 21 Sep 2026 13:23:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/subpath" aria-label="Profile: Subpath">@<bdi>Subpath</bdi></a> Great suggestion! I had mentioned this before as it applied the halftones panel. I ahdn't looked at the repeater panel. Seems worthy of adding that ability to link these values ​​together across any and all applicable tools in VS. That would certainly be an ease of use of upgrade.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33954</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33954</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Mon, 21 Sep 2026 13:23:30 GMT</pubDate></item><item><title><![CDATA[Reply to Repeater, be able to link values together on Mon, 21 Sep 2026 07:26:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/subpath" aria-label="Profile: Subpath">@<bdi>Subpath</bdi></a> I will add this to the features backlog.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33953</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33953</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 21 Sep 2026 07:26:26 GMT</pubDate></item></channel></rss>
