<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Exporting documents with raster images seem weird]]></title><description><![CDATA[<p dir="auto"><a href="/forum/assets/uploads/files/1788191774018-rastertest.zip">RasterTest.zip</a></p>
<p dir="auto">I put this raster image in a document → <img src="/forum/assets/uploads/files/1788191738174-circle.png" alt="Circle.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">And then I exported it twice, the first time without specifying the dimension, and the second time specifying the output dimension at 64 times the canvas size, then downscaling it by a factor of 64.</p>
<p dir="auto">The first export looks off by a pixel with the left and bottom edges looking weird. The second export looks fine.<br />
<img src="/forum/assets/uploads/files/1788191939791-exported-l.png" alt="Exported-l.png" class=" img-fluid img-markdown" /> <img src="/forum/assets/uploads/files/1788191945523-exported-downscale64-l.png" alt="Exported-downscale64-l.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Is this normal?</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5910/exporting-documents-with-raster-images-seem-weird</link><generator>RSS for Node</generator><lastBuildDate>Wed, 14 Oct 2026 13:08:55 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5910.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 31 Aug 2026 16:01:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Exporting documents with raster images seem weird on Tue, 01 Sep 2026 16:16:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/nocturnalyl" aria-label="Profile: nocturnalYL">@<bdi>nocturnalYL</bdi></a></p>
<p dir="auto">I tested this, and it can be replicated. The issue here is that when rendering at low resolution, the image is positioned at sub-pixel positions and the margin can be clipped.</p>
<p dir="auto">In this case there is no other way than using higher resolution rendering.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33891</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33891</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 01 Sep 2026 16:16:32 GMT</pubDate></item><item><title><![CDATA[Reply to Exporting documents with raster images seem weird on Mon, 31 Aug 2026 17:31:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/nocturnalyl" aria-label="Profile: nocturnalYL">@<bdi>nocturnalYL</bdi></a> Yes, the second export uses higher resolution (before downscaling)</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33886</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33886</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 31 Aug 2026 17:31:37 GMT</pubDate></item></channel></rss>
