<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Paste Objects in the Same Position Across Canvases]]></title><description><![CDATA[<p dir="auto">When copying objects from one canvas and pasting them onto another canvas within the same document, the objects should paste in the exact same relative position.</p>
<p dir="auto">For example, if an object is positioned 2 inches from the left edge and 3 inches from the top edge of Canvas 1, pasting it onto Canvas 2 should place it at those same coordinates.</p>
<p dir="auto">This would make it much easier to create consistent versions, color variations, alternate layouts, and production files across multiple canvases without manually repositioning the artwork each time.</p>
<p dir="auto">A separate Paste in Place command would also work, but ideally the existing paste behavior should preserve the original canvas coordinates when moving between canvases in the same file.</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5887/paste-objects-in-the-same-position-across-canvases</link><generator>RSS for Node</generator><lastBuildDate>Sat, 01 Aug 2026 13:26:13 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5887.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 01 Aug 2026 04:51:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Paste Objects in the Same Position Across Canvases on Sat, 01 Aug 2026 05:07:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> In Settings-&gt;Other Options there is a "Paste with Artboard Position" that must be turned on.</p>
<p dir="auto">Should there be separate actions with this option enabled?</p>
<p dir="auto">The problem is that there are multiple actions (including Paste on All Artboards) that must be duplicated for this</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33762</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33762</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sat, 01 Aug 2026 05:07:19 GMT</pubDate></item></channel></rss>
