<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is there a way to select small objects ?]]></title><description><![CDATA[<p dir="auto">I often need to clean up very small objects after some boolean operations.</p>
<p dir="auto">I thought I could use magic wand with Area or length checked and click on a small shape to select other similar objects. But it doesn't work anymore this way.</p>
<p dir="auto">How could this be achieved ?</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5866/is-there-a-way-to-select-small-objects</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 15:30:05 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5866.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Jul 2026 20:07:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is there a way to select small objects ? on Tue, 21 Jul 2026 14:33:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/subpath" aria-label="Profile: Subpath">@<bdi>Subpath</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: vectorstyler">@<bdi>vectorstyler</bdi></a> thanks, that's what I was looking for</p>
<p dir="auto">I did not realize that for open paths "larger" or "smaller" do not work and "longer" or "shorter" should be used instead</p>
<p dir="auto">thanks</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33694</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33694</guid><dc:creator><![CDATA[EricP]]></dc:creator><pubDate>Tue, 21 Jul 2026 14:33:28 GMT</pubDate></item><item><title><![CDATA[Reply to Is there a way to select small objects ? on Tue, 21 Jul 2026 04:29:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ericp" aria-label="Profile: EricP">@<bdi>EricP</bdi></a></p>
<p dir="auto">I think the Select Menu offers many options for such a case.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33668</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33668</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Tue, 21 Jul 2026 04:29:49 GMT</pubDate></item><item><title><![CDATA[Reply to Is there a way to select small objects ? on Mon, 20 Jul 2026 20:25:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ericp" aria-label="Profile: EricP">@<bdi>EricP</bdi></a> The area should work, but the tolerance might need to be larger.</p>
<p dir="auto">also: you can select shapes that are smaller than a selected shape with Select -&gt; Select by Shape -&gt; Smaller Shape</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33667</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33667</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 20 Jul 2026 20:25:08 GMT</pubDate></item></channel></rss>
