<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Text Stroke questions]]></title><description><![CDATA[<p dir="auto">Hi I am trying to apply a stroke effect to the outside of some text and have a couple of questions.</p>
<p dir="auto">When I set the alignment to "outside" (100%), if the outline is thick enough it bleeds over and covers part of the text, as you can see in the screenshot here (especially with the U, I, E and the top left of the S). I would like to have the outline stroke to never cover up the text it's outlining, no matter how thick I make it. This is how it works when I add a Stroke/Outline adjustment layer in most image editors.</p>
<p dir="auto">A related question, is there  a way to independently set the opacity and color mixing mode (Multiply, Screen, etc.) for just the Stroke of an object?</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1783914443238-screenshot-2026-07-12-at-23.46.32.png" alt="Screenshot 2026-07-12 at 23.46.32.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5858/text-stroke-questions</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Jul 2026 15:44:15 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5858.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Jul 2026 04:09:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Text Stroke questions on Mon, 13 Jul 2026 06:10:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/bunnzosteel" aria-label="Profile: BunnzoSteel">@<bdi>BunnzoSteel</bdi></a> said in <a href="/forum/post/33624">Text Stroke questions</a>:</p>
<blockquote>
<p dir="auto">text inside a text frame.</p>
</blockquote>
<p dir="auto">You need to use text shape (a.k.a point text) for this kind of stroke</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33625</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33625</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 13 Jul 2026 06:10:12 GMT</pubDate></item><item><title><![CDATA[Reply to Text Stroke questions on Mon, 13 Jul 2026 05:37:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Thanks for the quick response!</p>
<p dir="auto">I'm not sure how to use the Transform tool to select the text inside a text frame. If I click on the text, it selects the frame instead, and in the Layer inspector it only shows the text frame.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33624</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33624</guid><dc:creator><![CDATA[BunnzoSteel]]></dc:creator><pubDate>Mon, 13 Jul 2026 05:37:25 GMT</pubDate></item><item><title><![CDATA[Reply to Text Stroke questions on Mon, 13 Jul 2026 05:23:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/bunnzosteel" aria-label="Profile: BunnzoSteel">@<bdi>BunnzoSteel</bdi></a> said in <a href="/forum/post/33622">Text Stroke questions</a>:</p>
<blockquote>
<p dir="auto">When I set the alignment to "outside" (100%), if the outline is thick enough it bleeds over and covers part of the text, as you can see in the screenshot here (especially with the U, I, E and the top left of the S). I would like to have the outline stroke to never cover up the text it's outlining, no matter how thick I make it.</p>
</blockquote>
<p dir="auto">This depends how the stroke was selected. Use the regular transform tool to select the text (not the text tool), and then apply the stroke (so it is not a local character formatting attribute).<br />
(if this does not work, send me an example file by email)</p>
<blockquote>
</blockquote>
<p dir="auto">Yes, in the Appearance, open the "Stroke" style and click on the square box at the end of the row. In the menu you can find "Blend Mode".<br />
Or: select the "Stroke" item and set the blend mode in the Transparency panel.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33623</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33623</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 13 Jul 2026 05:23:30 GMT</pubDate></item></channel></rss>
