<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Moving the bitmap after using it to color repeated objects in a repeater]]></title><description><![CDATA[<p dir="auto">I have a question about coloring objects that are repeated<br />
in a Repeater and colored using a bitmap.</p>
<p dir="auto">My question is:<br />
Is there a way to select the bitmap used for coloring after the process is complete?<br />
At the moment, the bitmap simply disappears after running "Create in Largest Object"<br />
and "Create repeated Objects."</p>
<p dir="auto">I’ve been looking for a way to move the bitmap afterward—for instance, to align the object<br />
colors with a pattern in the bitmap—but I haven't been able to locate the bitmap anywhere<br />
(e.g., in the Layers panel).</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5848/moving-the-bitmap-after-using-it-to-color-repeated-objects-in-a-repeater</link><generator>RSS for Node</generator><lastBuildDate>Fri, 03 Jul 2026 08:33:33 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5848.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Jul 2026 04:59:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Moving the bitmap after using it to color repeated objects in a repeater on Fri, 03 Jul 2026 08:04:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/subpath" aria-label="Profile: Subpath">@<bdi>Subpath</bdi></a><br />
I changed the permissions to public, but I don't know why it won't let you view it without logging in. You can just download it directly</p>
<p dir="auto"><a href="https://drive.google.com/file/d/1ERwSPYi5IcxRtCytyMQ051rsJvPXd-qI/view?usp=drive_link" rel="nofollow ugc">https://drive.google.com/file/d/1ERwSPYi5IcxRtCytyMQ051rsJvPXd-qI/view?usp=drive_link</a></p>
]]></description><link>https://www.vectorstyler.com/forum/post/33578</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33578</guid><dc:creator><![CDATA[Li Xiao]]></dc:creator><pubDate>Fri, 03 Jul 2026 08:04:03 GMT</pubDate></item><item><title><![CDATA[Reply to Moving the bitmap after using it to color repeated objects in a repeater on Fri, 03 Jul 2026 07:54:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/li-xiao" aria-label="Profile: Li-Xiao">@<bdi>Li-Xiao</bdi></a></p>
<p dir="auto">The youtube video is still set as private so i cant see it<br />
Could you set it to public</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33577</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33577</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Fri, 03 Jul 2026 07:54:04 GMT</pubDate></item><item><title><![CDATA[Reply to Moving the bitmap after using it to color repeated objects in a repeater on Fri, 03 Jul 2026 07:27:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/li-xiao" aria-label="Profile: Li-Xiao">@<bdi>Li-Xiao</bdi></a></p>
<p dir="auto">Big thanks as always</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33575</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33575</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Fri, 03 Jul 2026 07:27:50 GMT</pubDate></item><item><title><![CDATA[Reply to Moving the bitmap after using it to color repeated objects in a repeater on Fri, 03 Jul 2026 05:45:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/subpath" aria-label="Profile: Subpath">@<bdi>Subpath</bdi></a> There is a very convenient workaround: just place the image inside a clipping frame, and then use the Repeater to color repeated objects. This way, you can see the image inside the Layers panel, select it, and freely move or scale it as you like.</p>
<p dir="auto"><a href="https://youtu.be/jYCNJfaVt54" rel="nofollow ugc">https://youtu.be/jYCNJfaVt54</a></p>
]]></description><link>https://www.vectorstyler.com/forum/post/33570</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33570</guid><dc:creator><![CDATA[Li Xiao]]></dc:creator><pubDate>Fri, 03 Jul 2026 05:45:11 GMT</pubDate></item><item><title><![CDATA[Reply to Moving the bitmap after using it to color repeated objects in a repeater on Fri, 03 Jul 2026 05:35:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/subpath" aria-label="Profile: Subpath">@<bdi>Subpath</bdi></a> The bitmap can be moved but it moves the whole repeater group.<br />
(repeated objects are positioned relative to the backdrop that is the bitmap)</p>
<p dir="auto">What you need is to adjust the offset of the repeated objects in the repeater options (second button in the repeater panel).</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33568</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33568</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 03 Jul 2026 05:35:54 GMT</pubDate></item></channel></rss>
