<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.3.020]]></title><description><![CDATA[<h3>VectorStyler 1.3.020 release notes</h3>
<li>Added an option to allow drawing parametric shapes with brush outlines</li>
<li>Added copying of text and number fields with right click</li>
<li>Allow negative spacing on the Overlay shape effect</li>
<li>Allow larger zoom levels if set in settings</li>
<li>Fixed a bug in converting paths to parametric curvature shapes</li>
<li>Fixed a crash caused by some variable fonts</li>
<li>Fixed a bug in positioning imported files when using drag and drop into the view</li>
<li>Fixed a DXF units importing issue</li>
<li>Fixed a bug in drawing a closed shape with the spline</li>
<li>Fixed an Illustrator embedded in PDF reading issue</li>
<li>Fixed an SVG importing problem</li>
<li>Fixed a GPU rendering issue with adjustment effects</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/5824/update-1.3.020</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 21:47:57 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5824.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 07 Jun 2026 13:26:28 GMT</pubDate><ttl>60</ttl></channel></rss>
