<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is there way to disable auto swap between the last and previous tool toggle effect?]]></title><description><![CDATA[<p dir="auto">Hi, I want to ask if it is possible to disable the behavior where pressing the shortcut for a single tool twice toggles back to the previously used tool. Basically, this behavior swaps between the current and previous tools when you use the same shortcut multiple times. I would like to disable this automatic toggling if only one shortcut exists for that specific tool. Before I request this as a new feature, I wanted to ask if there is already an existing setting where this can be disabled.</p>
<p dir="auto">Thanks, Michal.</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5822/is-there-way-to-disable-auto-swap-between-the-last-and-previous-tool-toggle-effect</link><generator>RSS for Node</generator><lastBuildDate>Sat, 06 Jun 2026 20:03:19 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5822.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 06 Jun 2026 13:26:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is there way to disable auto swap between the last and previous tool toggle effect? on Sat, 06 Jun 2026 14:15:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Thank you so much! <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/2764.png?v=ec4d969cc53" class="not-responsive emoji emoji-android emoji--heart" style="height:23px;width:auto;vertical-align:middle" title="&lt;3" alt="❤" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/33465</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33465</guid><dc:creator><![CDATA[mackotomi]]></dc:creator><pubDate>Sat, 06 Jun 2026 14:15:36 GMT</pubDate></item><item><title><![CDATA[Reply to Is there way to disable auto swap between the last and previous tool toggle effect? on Sat, 06 Jun 2026 13:43:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/mackotomi" aria-label="Profile: mackotomi">@<bdi>mackotomi</bdi></a> In Settings -&gt; Changing section: uncheck "Deactivate Tool with Shortcut"</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33464</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33464</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sat, 06 Jun 2026 13:43:49 GMT</pubDate></item></channel></rss>
