<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PDF fails to open and displays a blank artboard]]></title><description><![CDATA[<p dir="auto">I have recently encountered a serious problem with certain PDF files which refuse to display in VS. Any attempt to open these files will result in a blank artboard. The only workaround I currently have is to open the files in Illustrator and resave the PDF which then opens properly in VS.<br />
I have sent an example file to VectorStyler.</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5814/pdf-fails-to-open-and-displays-a-blank-artboard</link><generator>RSS for Node</generator><lastBuildDate>Mon, 25 May 2026 22:24:25 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5814.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 25 May 2026 15:26:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PDF fails to open and displays a blank artboard on Mon, 25 May 2026 16:40:43 GMT]]></title><description><![CDATA[<p dir="auto">Update:<br />
I found out why these PDFs were failing to display; I had the Import AI Data from PDF setting enabled and as soon as I disabled it, the PDFs are now opening in VS without any issues!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33423</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33423</guid><dc:creator><![CDATA[William Kansepa]]></dc:creator><pubDate>Mon, 25 May 2026 16:40:43 GMT</pubDate></item><item><title><![CDATA[Reply to PDF fails to open and displays a blank artboard on Mon, 25 May 2026 15:48:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/william-kansepa" aria-label="Profile: William-Kansepa">@<bdi>William-Kansepa</bdi></a> I will open a bug on this.<br />
See the email for details.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33422</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33422</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 25 May 2026 15:48:10 GMT</pubDate></item></channel></rss>
