<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.3.019]]></title><description><![CDATA[<h3>VectorStyler 1.3.019 release notes</h3>
<li>Fixed a bug in EPS file importing</li>
<li>Fixed a bug with the Envelope checkbox</li>
<li>Fixed bug in super ellipse precision</li>
<li>Fixed a bug in SVG exporting with units</li>
<li>Fixed bug in scaling inside transformed layers</li>
<li>Fixed a stroke overprint issue</li>
<li>Fixed a bug in the extended text engine with rotated roman text inside vertical text</li>
<li>Fixed a bug in opacity rendering of single clipped objects</li>
<li>Added actions to select clone or source objects</li>
<li>Added angle constrain mode to drop shadow editing</li>
<li>Added copy paste options to the Appearance panel menu</li>
<li>Remove empty text frames when merging shapes</li>
<li>Option to configure modifier to join selection without removing</li>
<li>Block alignment should not align to artboard</li>
<li>Do not use multiple sampling while dragging objects in GPU preview mode</li>
<li>Use transform each mode when pasting object size</li>
<li>Improved cursor rendering on Windows</li>
<li>Fixed a bug in large zoom highlight rendering</li>
<li>Fixed an NVidia CUDA compatibility issue</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/5811/update-1.3.019</link><generator>RSS for Node</generator><lastBuildDate>Mon, 25 May 2026 22:22:08 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5811.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 25 May 2026 06:49:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.3.019 on Mon, 25 May 2026 21:38:13 GMT]]></title><description><![CDATA[<p dir="auto">Just thinking about it, some of these minor updates would easily be passed as a major update in Affinity. It did give me a chuckle. The continued work that is going into this project is astonishing, honestly.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33426</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33426</guid><dc:creator><![CDATA[debraspicher]]></dc:creator><pubDate>Mon, 25 May 2026 21:38:13 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.3.019 on Mon, 25 May 2026 17:37:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Thank you! Great fixes and improvements.</p>
<p dir="auto">EPS file is working now. Angle constrain mode in drop shadow is a helpful addition. Love the ability to now copy settings from the appearance panel to another shape so quickly and easily! Thank you as well for making it easier to merge down a design that may have hidden empty text frames</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33424</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33424</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Mon, 25 May 2026 17:37:56 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.3.019 on Mon, 25 May 2026 08:33:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/li-xiao" aria-label="Profile: Li-Xiao">@<bdi>Li-Xiao</bdi></a> The new NVidia CUDA redistributable (version 13.2) is 92 megabytes.<br />
The previous version 10.2 was only 15 megabytes.<br />
Why this difference is not clear, but this is needed to run CUDA code</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33403</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33403</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 25 May 2026 08:33:14 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.3.019 on Mon, 25 May 2026 08:10:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> The Windows installer for version 1.3.019 is over 32MB larger than version 1.3.018, whereas the macOS installer size remains roughly the same. What is the reason for this?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33402</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33402</guid><dc:creator><![CDATA[Li Xiao]]></dc:creator><pubDate>Mon, 25 May 2026 08:10:19 GMT</pubDate></item></channel></rss>
