<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Pattern Brush made into Art brush will not expand Properly]]></title><description><![CDATA[<p dir="auto">I am having trouble expanding a pattern that I used to make into a brush stroke.</p>
<p dir="auto">I'm using the most recent VS build as of today.</p>
<p dir="auto">I want to expand my brush stroke into individual pieces but instead VS displays them as a grid.</p>
<p dir="auto">I made an artistic brush using an expanded pattern shape. I then applied that brush to a stroke, and edited it to fit the desired shape. After that, i tried to expand the stroke brush in order to merge it, once that was done, it appeared fuzzy and the selection lines displayed the stroke as if it was in a grid pattern, as shown in the attached image.</p>
<p dir="auto">I have attached a <a href="/forum/assets/uploads/files/1778529971243-example-file.vstyler">Example File.vstyler</a> for this showing the path before it was expanded, then under that, after it was expanded.</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1778531665362-8c561dae-2a90-4245-8c8c-60ef48a36055-cleanshot-2026-05-11-at-16.34.01@2x.png" alt="8c561dae-2a90-4245-8c8c-60ef48a36055-CleanShot 2026-05-11 at 16.34.01@2x.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/forum/assets/uploads/files/1778528524046-cleanshot-2026-05-11-at-15.39.16@2x.png" alt="CleanShot 2026-05-11 at 15.39.16@2x.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I'm also getting a strange visual on the pattern when zoomed in. might just be a glitch in the visual.<br />
<img src="/forum/assets/uploads/files/1778531619993-d119c9b1-a20b-4ad3-8c10-6c471507f126-cleanshot-2026-05-11-at-16.32.29@2x.png" alt="d119c9b1-a20b-4ad3-8c10-6c471507f126-CleanShot 2026-05-11 at 16.32.29@2x.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5785/pattern-brush-made-into-art-brush-will-not-expand-properly</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 07:25:24 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5785.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 May 2026 20:34:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Pattern Brush made into Art brush will not expand Properly on Tue, 12 May 2026 04:20:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Thank you for looking into it, and helping me find a solution.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33279</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33279</guid><dc:creator><![CDATA[Ridgehammer]]></dc:creator><pubDate>Tue, 12 May 2026 04:20:44 GMT</pubDate></item><item><title><![CDATA[Reply to Pattern Brush made into Art brush will not expand Properly on Mon, 11 May 2026 23:22:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ridgehammer" aria-label="Profile: Ridgehammer">@<bdi>Ridgehammer</bdi></a> Can be replicated. The brush has the "Distort as an Image" option enabled, this is not needed here, if disabled it will work correctly</p>
<p dir="auto">I will try to find out what can cause this.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33276</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33276</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 11 May 2026 23:22:53 GMT</pubDate></item></channel></rss>
