<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Keyboard shortcut for &quot;Break Shape&quot;-option, how?]]></title><description><![CDATA[<p dir="auto">I wan't to make a keyboard shortcut for "Break Shape"-option, but I can't find and apply it in the Contextual Menu list. Can you please help me?</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1778226648143-923e8e4f-de7e-4fb5-a934-ca91a6239b04-image.png" alt="923e8e4f-de7e-4fb5-a934-ca91a6239b04-image.png" class=" img-fluid img-markdown" /> <img src="/forum/assets/uploads/files/1778226208440-d652af07-13b1-417a-b783-3a6d7a74d910-image.png" alt="d652af07-13b1-417a-b783-3a6d7a74d910-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5770/keyboard-shortcut-for-break-shape-option-how</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 09:00:51 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5770.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 May 2026 07:54:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Keyboard shortcut for &quot;Break Shape&quot;-option, how? on Fri, 08 May 2026 09:05:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a><br />
Ah, great. Got it.</p>
<p dir="auto">Update with a note: One have to check for conflicting shortkeys already set for other operations. Else it won't work.</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1778230120509-ee388d5e-42b9-4386-bcc5-a7e4371723f9-image.png" alt="ee388d5e-42b9-4386-bcc5-a7e4371723f9-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/33207</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33207</guid><dc:creator><![CDATA[Raaskot]]></dc:creator><pubDate>Fri, 08 May 2026 09:05:30 GMT</pubDate></item><item><title><![CDATA[Reply to Keyboard shortcut for &quot;Break Shape&quot;-option, how? on Fri, 08 May 2026 08:42:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/raaskot" aria-label="Profile: Raaskot">@<bdi>Raaskot</bdi></a></p>
<p dir="auto">For keyboard shortcuts you do not need to work with the "Contextual Menu"</p>
<p dir="auto">In the "Keyboard Shortcuts" view:</p>
<li>Leave the "Context" field to "Application Shortcuts" (for simplicity)</li>
<li>on the right side "Actions" list navigate to Object -&gt; Shape -&gt; Break Shape and select it</li>
<li>click on the "Add Shortcut" button (first in the bottom of the "Keyboard Shortcuts" view)</li>
<li>this will show and highlight the new shortcut item without an assigned key</li>
<li>click into the second column and press the keyboard shortcut you want to use</li>
<li>the you can confirm the "Keyboard Shortcuts" view</li>
<p dir="auto">I tested this here just now and it worked</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33205</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33205</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 08 May 2026 08:42:41 GMT</pubDate></item></channel></rss>
