<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cannot be pasted in situ]]></title><description><![CDATA[<p dir="auto">1.How can I paste the shapes of 1.2 identical sized drawing boards on drawing board 1 in their original positions on drawing board 2?<br />
2.<img src="/forum/assets/uploads/files/1778226559466-screenshot_2026-05-08_154151_372.png" alt="ScreenShot_2026-05-08_154151_372.png" class=" img-fluid img-markdown" /> Why can't 'i' be selected in isolation mode? You must click on the layer panel to select it.</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5769/cannot-be-pasted-in-situ</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 08:15:36 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5769.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 May 2026 07:51:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cannot be pasted in situ on Fri, 08 May 2026 12:30:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/macos" aria-label="Profile: macos">@<bdi>macos</bdi></a> Will be added</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33216</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33216</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 08 May 2026 12:30:53 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot be pasted in situ on Fri, 08 May 2026 12:03:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a><br />
It is recommended to implement this feature, as it can sometimes be quite useful.<br />
Illustrator is fine.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33215</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33215</guid><dc:creator><![CDATA[macos]]></dc:creator><pubDate>Fri, 08 May 2026 12:03:13 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot be pasted in situ on Fri, 08 May 2026 10:37:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/macos" aria-label="Profile: macos">@<bdi>macos</bdi></a> said in <a href="/forum/post/33210">Cannot be pasted in situ</a>:</p>
<blockquote>
<p dir="auto">I copied it on drawing board 1 and want to paste it on drawing board 2 while keeping it in the same position as drawing board 1.</p>
</blockquote>
<p dir="auto">When pasted on the other artboard, it will be centered. Not possible to paste at the same location on the new artboard.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33212</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33212</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 08 May 2026 10:37:22 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot be pasted in situ on Fri, 08 May 2026 09:04:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a><br />
I copied it on drawing board 1 and want to paste it on drawing board 2 while keeping it in the same position as drawing board 1. What should I do?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33210</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33210</guid><dc:creator><![CDATA[macos]]></dc:creator><pubDate>Fri, 08 May 2026 09:04:08 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot be pasted in situ on Fri, 08 May 2026 08:46:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/macos" aria-label="Profile: macos">@<bdi>macos</bdi></a></p>
<ol>
<li>
<p dir="auto">The default Paste command pastes into the center of the view.<br />
"Paste in Place" should keep the position</p>
</li>
<li>
<p dir="auto">Not sure of this, if you send me that example I can tell more?<br />
In VS there are two different isolation modes: "inside" or "selection".<br />
This seems to be "inside", so now you are drawing inside the "i" shape, which means you cannot select "i" (only its content, which is empty according to the layers panel).<br />
To select "i" you need to exit the isolation mode and then single-click on "i"</p>
</li>
</ol>
]]></description><link>https://www.vectorstyler.com/forum/post/33206</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33206</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 08 May 2026 08:46:50 GMT</pubDate></item></channel></rss>
