<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Adding more magnetism to the arc tool when closing a path]]></title><description><![CDATA[<p dir="auto">With the new arc tool, could we set the magnet pull when you are close to completing a closed path like what is already set with the pen tool?</p>
<p dir="auto"><a href="https://cleanshot.com/share/Kvd0Mmwg" rel="nofollow ugc">When I create an arc with the arc tool and I go to complete a shape by clicking on the original node, it appears to "lock-in" but not really, it always leaves a small gap</a><br />
If we gave it the same setting s as what the pen tool uses, it was be much easier to get a closed shape quickly.</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1777522650428-e9386d26-a2ba-4db6-be05-f5f5340ef732-cleanshot-2026-04-30-at-00.17.04.png" alt="e9386d26-a2ba-4db6-be05-f5f5340ef732-CleanShot 2026-04-30 at 00.17.04.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5746/adding-more-magnetism-to-the-arc-tool-when-closing-a-path</link><generator>RSS for Node</generator><lastBuildDate>Sat, 02 May 2026 07:53:34 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5746.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 30 Apr 2026 04:18:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Adding more magnetism to the arc tool when closing a path on Thu, 30 Apr 2026 13:27:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> thank you - yes, if I turn on snapping, it will close the path as expected. I did notice however, it does not work as well on non-circle results like I was demonstrating. If the shape is not a circle, even with the snapping on, it will not join together properly. <a href="https://cleanshot.com/share/vGxFmSfx" rel="nofollow ugc">here is a video showing this</a></p>
<p dir="auto">In the video, I also show how it would be helpful if the snapping would show the midpoint of the path nearby in this case right below it so I could make my node centered if I wanted to. Does this go against the principle of the tool? Because I understand it's meant to be an on the fly adjustment as you work not necessarily technical.</p>
<p dir="auto">Even as a general option for all plotting tools - it would be handy to have snapping indicate when you are at the center point of a nearby path. it works in VS when there is already a node there to represent that spot <a href="https://cleanshot.com/share/lD0dbKlZ" rel="nofollow ugc">like in this video</a></p>
<p dir="auto">The end of the video cuts to the open source "<a href="https://graphite.art/" rel="nofollow ugc">Graphite</a>" where it allows for that kind of thing</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33087</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33087</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Thu, 30 Apr 2026 13:27:33 GMT</pubDate></item><item><title><![CDATA[Reply to Adding more magnetism to the arc tool when closing a path on Thu, 30 Apr 2026 11:05:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> There should be snapping by default:<br />
I get this with the default settings (and snapping enabled in the Snapping panel):<br />
<a href="https://cleanshot.com/share/SRGlWty7" rel="nofollow ugc">https://cleanshot.com/share/SRGlWty7</a></p>
]]></description><link>https://www.vectorstyler.com/forum/post/33086</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33086</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Thu, 30 Apr 2026 11:05:39 GMT</pubDate></item></channel></rss>
