<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Change Screen Mode does not work]]></title><description><![CDATA[<p dir="auto">This has always been a long-time challenge. Change Screen Mode is buggy as it does not function as expected.</p>
<li>
<p dir="auto">When you switch from the default Normal Screen to the Full Screen Mode, there is no noticeable difference between the two.</p>
</li>
<li>
<p dir="auto">If you switch to the Single Screen Mode, everything disappears and the screen goes blank (there is only a black screen). During this pickle you can create new documents by pressing Control+N but these won't show. Pressing the Escape key sometimes work but most of the time it doesn't. Currently, the only foolproof solution is to use the task manager to kill the VS process, restart VS and everything then goes back to normal.</p>
</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/5740/change-screen-mode-does-not-work</link><generator>RSS for Node</generator><lastBuildDate>Sun, 26 Apr 2026 06:17:07 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5740.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 25 Apr 2026 21:29:05 GMT</pubDate><ttl>60</ttl></channel></rss>
