<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Arrange order icons - more intuitive and clean option?]]></title><description><![CDATA[<p dir="auto">the "arrange order" icons in Affinity seem more intutive to me than what we have in VS and it looks cleaner:</p>
<p dir="auto">Here's Affinity's icon set<br />
<img src="/forum/assets/uploads/files/1776788415668-1fc45bd6-5a5e-4d60-ab59-9fc96d7309cc-cleanshot-2026-04-21-at-12.16.02.png" alt="1fc45bd6-5a5e-4d60-ab59-9fc96d7309cc-CleanShot 2026-04-21 at 12.16.02.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Here is VS:<br />
<img src="/forum/assets/uploads/files/1776788539771-57033683-deac-47c0-b71a-989abb64d028-cleanshot-2026-04-21-at-12.22.04.png" alt="57033683-deac-47c0-b71a-989abb64d028-CleanShot 2026-04-21 at 12.22.04.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I like that they can all be in one drop down grouping - making the UI cleaner and preserving more space at the upper level for other future icons for other tools.</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5735/arrange-order-icons-more-intuitive-and-clean-option</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 15:47:43 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5735.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 21 Apr 2026 16:23:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Arrange order icons - more intuitive and clean option? on Wed, 22 Apr 2026 09:03:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/debraspicher" aria-label="Profile: debraspicher">@<bdi>debraspicher</bdi></a></p>
<p dir="auto">I am a more mouse oriented user and avoid Shortcuts if i can.<br />
Like to use my second hand to drink a coffee. <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=ec4d969cc53" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
<p dir="auto">One key shortcuts are fine, two keys also ok. But 3 key shortcuts<br />
sorry, didnt like it. Of course i know Shortcuts allows to work faster,<br />
but i am not in need to be the fastest.</p>
<p dir="auto">To arrange the Order of Objects is also needed with Booleans,<br />
take the "Substract Boolean" as an Example where the order matters.</p>
<p dir="auto">Been using Xara for a while Coreldraw too, in both you could create<br />
your own Toolbar which i did.</p>
<p dir="auto">Its also possibel to create your own Toolbar in Vectorstyler<br />
but sadly they are not free scalable like in Xara and Corel.<br />
So i didnt use this.</p>
<p dir="auto">Here a Toolbar Example from Coreldraw:</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1776848567040-ksnip_20260422-110127.png" alt="ksnip_20260422-110127.png" class=" img-fluid img-markdown" /><br />
.<br />
.<br />
<img src="/forum/assets/uploads/files/1776848574605-ksnip_20260422-110154.png" alt="ksnip_20260422-110154.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/33015</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33015</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Wed, 22 Apr 2026 09:03:02 GMT</pubDate></item><item><title><![CDATA[Reply to Arrange order icons - more intuitive and clean option? on Wed, 22 Apr 2026 06:37:25 GMT]]></title><description><![CDATA[<p dir="auto">Just to add to the general poll, I use keyboard shortcuts for managing layer stacks if I want to do that and most of the time it's to push something to the bottom of the stack. I use the menus to refresh myself of which key combinations to use for these scenarios.</p>
<p dir="auto">In Affinity's case, it makes sense why they've placed "Send to Back" as a default at the top as it's an often used shortcut in many workflows. However, it's also only a one shot press when used. It does not require successive clicks.</p>
<p dir="auto">The 2nd/3rd options are often used by used for keyboard bound users because it's easier to press that option successively with a shortcut until it's properly moved where it needs to be in the stack. For mouse heavy users, it's easiest to just drag the selection in the Layers panel, but of course it depends on how many objects/layers it's being moved between...</p>
<p dir="auto">Send to Front isn't often used for multiple selections and even if so, Send to Back might actually be more intuitive to work with. Clicking an object/group in the front of the stack is quickest. To get to the object in the back of the stack, that person might already be in the Layers panel possibly anyway so the 2-click access isn't that much work...</p>
<p dir="auto">I don't think either method is "bad". I would say the one that has all the options laid out is more for touch or tablet users who don't want to access the keyboard nearly as often. I'm a bit of both but only tablet when needed. . I have a pull tray/drawer I attached to my table to put my large tablet into when it's not being used because I find that I have a better grip of the interface usually when I'm mouse &amp; keyboard-only.</p>
<p dir="auto">I don't think these icons make it less tidy at all, but I'm on a 4K setup so it may look very different for a laptop user.. I can understand why Affinity needs tidying because they've applied metamorphic rock processes to their applications and so users need clearheaded, decisive labeling and lots and lots of tabbing just to get around and even access the basics...</p>
<p dir="auto">Anyway, just some thoughts.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33014</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33014</guid><dc:creator><![CDATA[debraspicher]]></dc:creator><pubDate>Wed, 22 Apr 2026 06:37:25 GMT</pubDate></item><item><title><![CDATA[Reply to Arrange order icons - more intuitive and clean option? on Wed, 22 Apr 2026 04:54:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a></p>
<p dir="auto">It's Vectorstyler's decision, of course, what he wants to do.<br />
As always, I'm just expressing my personel preferences or dislikes<br />
and i like it in the way it is by now.</p>
<p dir="auto">Now, in both cases, I see an additional step that isn't needed at the moment.<br />
Although in the second case, the additional step might be less frequent.</p>
<p dir="auto">All this just to make it look tidier? I actually find the icon bar at the top quite tidy.<br />
Although I do miss a few Boolean icons that were displayed before.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33012</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33012</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Wed, 22 Apr 2026 04:54:26 GMT</pubDate></item><item><title><![CDATA[Reply to Arrange order icons - more intuitive and clean option? on Tue, 21 Apr 2026 18:14:46 GMT]]></title><description><![CDATA[<p dir="auto">The two clicks does not bother me personally but I respect that its an issue for others. What about an option to let the user condense or leave expanded the view? Similar to what we can do with panels to show a minimalist set of tools, double click to see more, etc. Not that it's identical, just the concept</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33011</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33011</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Tue, 21 Apr 2026 18:14:46 GMT</pubDate></item><item><title><![CDATA[Reply to Arrange order icons - more intuitive and clean option? on Tue, 21 Apr 2026 17:28:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a><br />
<a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: vectorstyler">@<bdi>vectorstyler</bdi></a></p>
<p dir="auto">I am against of solution like in Affinity.</p>
<p dir="auto">Because one use these order icons soo often<br />
i want a easy and fast way to reach them.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33010</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33010</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Tue, 21 Apr 2026 17:28:40 GMT</pubDate></item><item><title><![CDATA[Reply to Arrange order icons - more intuitive and clean option? on Tue, 21 Apr 2026 16:47:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> yes, but that is two clicks to access</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33009</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33009</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 21 Apr 2026 16:47:41 GMT</pubDate></item></channel></rss>
