<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[So many pen alternatives. How to make sense of them?]]></title><description><![CDATA[<p dir="auto">I am very new to VectorStyler and wanting to get my head around all of these different curve creation options and how to efficiently use them. I was thrilled to see the Bezigon tool make an appearance as I loved using that in Freehand. However, I don't think it behaves quite the same. For one thing, after creation, the points and handles behave just like a standard Bezier handles I think. Not adjusting as you drag to keep some automatic curvature.<br />
And there is the curvature tool: It behaves somewhat like the Illustrator tool of the same name but not quite.<br />
And then the Interpolated Shape tool. It looks like some kind of B-Spline. Maybe like a 2nd degree NURBS?<br />
And the one labled B-Spline seems kinda like a cubic NURBS curve except that every third click after the first one creates a sharp point.<br />
Then the Spline Tool seems kinda like the Illustrator Curve tool or maybe like the Affinity automatic point setting. But while drawing it creates curve points unless you click with Alt. Then you get a sharp point but the next one too is also sharp even without Alt. Then it goes back to being curved.<br />
It would be great to have some kind of definitive guide to how to use these various tools with the proper modifier keys engaged. A video demo would be awesome. I love all of the choices but it is overwhelming and very unclear to me.<br />
Any suggestions for learning these and getting into a good workflow?<br />
thanks.</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5727/so-many-pen-alternatives.-how-to-make-sense-of-them</link><generator>RSS for Node</generator><lastBuildDate>Sat, 04 Apr 2026 14:06:38 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5727.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Apr 2026 19:25:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to So many pen alternatives. How to make sense of them? on Fri, 03 Apr 2026 20:13:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/thatmikeguy" aria-label="Profile: ThatMikeGuy">@<bdi>ThatMikeGuy</bdi></a> A brief description: there are two groups of curve drawing tools</p>
<p dir="auto">How to use these is up to the users, some are present in other illustration apps also so they may be familiar.</p>
<p dir="auto">group 1: these are more commonly used</p>
<p dir="auto">Pen - this is the regular pen tool<br />
Pencil - similar to other apps, painting curves<br />
Path Sketch - this is VectorStyler specific, similar to Pencil but can intersect+union the curves as you draw<br />
Brush - these are real vector brushes (that is, the content of the brush is also vector)<br />
Line - well, a simple line tool</p>
<p dir="auto">group 2: these are a bit more complicated, some of these are present in other apps also.<br />
these can be of two type: parametric (retains editability), or just directly creating cubic Beziers</p>
<p dir="auto">The first 3 are creating regular paths with lines and curves:<br />
Curvature tool: creates a bezier shape with smooth curvature (similar to Illustrator)<br />
Bezigon tool: (similar to Freehand) lines and beziers (press Option/Alt for beziers)<br />
Arc tool: curves drawn as arcs</p>
<p dir="auto">The next 4 create parametric (live) shapes interpolating a sequence of points with various methods:<br />
Interpolated Shape: cubic interpolation, you can select the interpolation method in the Shape panel (or in the top row)<br />
B-Spline - interpolating B-Spline over a sequence of points, set the degree of interpolation in the panel<br />
Spline - cubic interpolating splines<br />
Curvature Shape - same as the Curvature tool, but retains the line shape and you can set the curvature precision in the Shape panel</p>
]]></description><link>https://www.vectorstyler.com/forum/post/32960</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/32960</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 03 Apr 2026 20:13:14 GMT</pubDate></item></channel></rss>
