    Duplicate object with mouse and keyboard. How?
    4 Posts 4 Posters 17 Views 4 Watching
    • M Online
      marce
      Hi! It`s pretty standard in windows to duplicate and object to select the object and drag it, while pressing the "Control" key. In Inkscape you do this with "Ctrl+D" (that is pretty weird imho). How can i duplicate an object with my mouse?
      Self answer after trying: Using "Alt" instead of "Control".
      I post the message anyway, i believe someone can found it helpful.
      I would love to see some videos explaining the most basic things of VS, that are not pretty standard -and is ok- but that make me lost and dizzy when trying to work with VS.
      Memory 48gb ddr4
      NVMe CT100p 1TB
      L VectorStylerV S 3 Replies Last reply Reply Quote 1
      • L Offline
        Li Xiao @marce
        @marce
        Please take a look here:
        https://www.vectorstyler.com/forum/topic/5322/copying-objects-in-vectorstyler-with-the-right-mouse-button?_=1771511733541
          VectorStyler @marce
          @marce When dragging with the mouse, hold the Alt+ key, this is standard in drawing apps.
          Otherwise, the Control+D should create a duplicate of then selected object
            Subpath @marce
            @marce
            I use the methode @li-xiao mentioned all the time
            if i copy objects in VS. I hate to use keys if i could
            use the mouse to do it.
            Xara has one of the best copy procedure i found.
            Just select a object with the right mouse button
            and it will be copied, place the copy where you like it
            and release the right mouse button
            VS copy method via the right mouse Button works pretty
            well. Its similar how it works in CorelDraw.
            Btw.
            Duplicate via Ctrl+D is different to a simple copy.
            If you duplicate a Object and move or rotate it
            press Ctrl+D again will place addional copys
            with the same distance. So Ctrl+D is helpful.
