<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Question about using Paths with Composite Shape Boolean]]></title><description><![CDATA[<p dir="auto">At first, are Paths allowed to be used with Composite Shape Booleans<br />
e.g Enclosure ? It works but I encountered, some unusual things.<br />
.<br />
.<br />
I've explored some ideas of using composition shape booleans with paths<br />
and found that paths can also be used this way.<br />
However, I encountered, well, let's say, unusual things.</p>
<p dir="auto">I created a rectangle from four independent paths and the<br />
Composite Shape Boolean Enclosure.</p>
<p dir="auto">All four paths can be individually selected and moved<br />
independently with the shape tool. So far, so good.</p>
<p dir="auto">They can also be selected and bent with the Node tool.<br />
However, the end node of a path cannot be selected and<br />
moved. Or rather, it works with some paths, but more often<br />
it doesn't.</p>
<p dir="auto">However, if I insert a node into the path, this node can be moved.<br />
Any Reason for this Behaviour ?</p>
<p dir="auto"><a href="https://go.screenpal.com/watch/cTfV17niJDw" rel="nofollow ugc">Here a Video</a></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5064/question-about-using-paths-with-composite-shape-boolean</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 14:13:48 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5064.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Apr 2025 06:57:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Question about using Paths with Composite Shape Boolean on Tue, 01 Apr 2025 08:18:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/29479">Question about using Paths with Composite Shape Boolean</a>:</p>
<blockquote>
<p dir="auto">First create group from the 4 lines.</p>
</blockquote>
<p dir="auto">Thanks!<br />
Seems that this was the solution, to group the paths first<br />
and then applying the composite shape mode. Its working<br />
so far.</p>
<p dir="auto">Made a Video for everyone who is interested.<br />
To create a "normal" Shape from that use<br />
"Expand Appearance"</p>
<p dir="auto"><a href="https://go.screenpal.com/watch/cTfVjXniJuY" rel="nofollow ugc">Here the Video which shows the Steps</a></p>
]]></description><link>https://www.vectorstyler.com/forum/post/29480</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/29480</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Tue, 01 Apr 2025 08:18:21 GMT</pubDate></item><item><title><![CDATA[Reply to Question about using Paths with Composite Shape Boolean on Tue, 01 Apr 2025 07:10:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/subpath" aria-label="Profile: Subpath">@<bdi>Subpath</bdi></a> try creating the composite shape with groups (this is similar to Illustrator).<br />
First create group from the 4 lines.<br />
Then select a composite operator.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/29479</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/29479</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 01 Apr 2025 07:10:04 GMT</pubDate></item><item><title><![CDATA[Reply to Question about using Paths with Composite Shape Boolean on Tue, 01 Apr 2025 07:08:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/subpath" aria-label="Profile: Subpath">@<bdi>Subpath</bdi></a> said in <a href="/forum/post/29477">Question about using Paths with Composite Shape Boolean</a>:</p>
<blockquote>
<p dir="auto">Paths allowed to be used with Composite Shape Booleans e.g Enclosure ?</p>
</blockquote>
<p dir="auto">Yes.</p>
<blockquote>
<p dir="auto">However, if I insert a node into the path, this node can be moved.</p>
</blockquote>
<p dir="auto">I think this might be a bug in the node selection.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/29478</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/29478</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 01 Apr 2025 07:08:34 GMT</pubDate></item></channel></rss>
