<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Settings Preset runs a check to see if active preset file is saved to current settings before switching presets]]></title><description><![CDATA[<p dir="auto">Could we add an option in the Settings preset section to make it noticeable if edits have been made to the settings that are different from the saved file?<br />
So if I create a custom preset in the settings panel and save it and make it active in VS, if I go along and modify the settings afterward, there's no way for me to know later on if those adjusted settings have been saved in that preset or not (unless I rely on my own memory)<br />
When I want to switch between my custom settings preset and the default, I am always wondering if I need to re-save the custom preset because I may have updated the settings over time since I last made that custom preset active. or I may want to save out what is newly edited in the preset settings and create a new custom preset file.</p>
<p dir="auto">I propose either adding an asterisk by the setting or have VS offer a popup warning that the preset setting has been edited and can be saved, a new preset created and saved or the changes can be ignored by the user. Sort of like what happens currently with a VS file we've edited when we go to close it out.</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/4883/settings-preset-runs-a-check-to-see-if-active-preset-file-is-saved-to-current-settings-before-switching-presets</link><generator>RSS for Node</generator><lastBuildDate>Sun, 09 Aug 2026 00:30:06 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/4883.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 21 Dec 2024 17:16:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Settings Preset runs a check to see if active preset file is saved to current settings before switching presets on Sat, 21 Dec 2024 18:29:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> I will try to implement this.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/28386</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/28386</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sat, 21 Dec 2024 18:29:22 GMT</pubDate></item></channel></rss>
