<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Data Source] Bugs and request]]></title><description><![CDATA[<p dir="auto">Finally, I prepared a project to automate my work with the cutting plotter.<br />
The project is to take the data and put the corresponding names in the 6 fields of each artboard.<br />
Currently, I have prepared a CSV file that has 6 columns corresponding to each field. Is this a good solution? Or is there a way to have the fields filled in sequentially from one column?<br />
<img src="/forum/assets/uploads/files/1729708043399-screenshot-2024-10-23-202614-resized.png" alt="0_1729708042484_Screenshot 2024-10-23 202614.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">During the process, I encountered some problems:<br />
1.Undoing the changes deletes the artboards, but the data remains in place. Data connection also does not work<br />
2. Sometimes there are problems with missing data or the size of the text changes, and a refresh is necessary.</p>
<p dir="auto"><a href="https://somup.com/cZ60b4HG3B" rel="nofollow ugc">https://somup.com/cZ60b4HG3B</a></p>
<p dir="auto">The length of the lists will vary, and I would like VS to calculate the required number of artboards by itself. By default, only 4 artboards are created. I can see that this should not be a problem, because by defining more artboards  in ' Canvas Data Grid'  options only as many as needed are used.</p>
<p dir="auto"><a href="https://somup.com/cZ60bBHG01" rel="nofollow ugc">https://somup.com/cZ60bBHG01</a></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/4717/data-source-bugs-and-request</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 12:47:55 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/4717.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 23 Oct 2024 18:25:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Data Source] Bugs and request on Sat, 09 Nov 2024 17:40:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a><br />
Indeed, fixed. thank you</p>
]]></description><link>https://www.vectorstyler.com/forum/post/27744</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/27744</guid><dc:creator><![CDATA[encart]]></dc:creator><pubDate>Sat, 09 Nov 2024 17:40:35 GMT</pubDate></item><item><title><![CDATA[Reply to [Data Source] Bugs and request on Thu, 07 Nov 2024 23:39:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/encart" aria-label="Profile: encart">@<bdi>encart</bdi></a> This issue should be fixed in build 1.2.046</p>
]]></description><link>https://www.vectorstyler.com/forum/post/27710</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/27710</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Thu, 07 Nov 2024 23:39:13 GMT</pubDate></item><item><title><![CDATA[Reply to [Data Source] Bugs and request on Wed, 23 Oct 2024 19:09:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/encart" aria-label="Profile: encart">@<bdi>encart</bdi></a> said in <a href="/forum/post/27493">[Data Source] Bugs and request</a>:</p>
<blockquote>
<p dir="auto">Is this a good solution?</p>
</blockquote>
<p dir="auto">yes</p>
<blockquote>
<p dir="auto">Or is there a way to have the fields filled in sequentially from one column?</p>
</blockquote>
<p dir="auto">No, each column will define a variable that can be used in the document</p>
<blockquote>
<p dir="auto">1.Undoing the changes deletes the artboards, but the data remains in place. Data connection also does not work</p>
</blockquote>
<p dir="auto">I will try to replicate this.</p>
<blockquote>
<ol start="2">
<li>Sometimes there are problems with missing data or the size of the text changes, and a refresh is necessary.</li>
</ol>
</blockquote>
<p dir="auto">I think the issue here is the canvas grid feature. This will create separate layers, each with a fixed row, so changing the row will not work. I will try to solve the undo issue.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/27495</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/27495</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 23 Oct 2024 19:09:31 GMT</pubDate></item></channel></rss>
