<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.2.040]]></title><description><![CDATA[<h3>VectorStyler 1.2.040 release notes</h3>
<li>Improved offset stroke handling for thin stroke width.</li>
<li>Added settings to cache symbol instances.</li>
<li>Fixed a bug when flipping objects that are already transformed.</li>
<li>Allow setting default stroke options from the context panel also.</li>
<li>Highlight layer name by default in object options view.</li>
<li>Fixed a bug in the select inside shape feature.</li>
<li>Fixed a bug in fill and stroke style handling of text shapes.</li>
<li>Automatically determine alignment direction when aligning side by side.</li>
<li>Fixed a Unicode exception issue with capitalization in the Turkish language.</li>
<li>Fixed a spacing issue in the wave and zigzag grid shapes.</li>
<li>Consolidated the context panel options of the Pen tool into a single button with a menu.</li>
<li>Fixed an issue with importing arrowheads from AI files.</li>
<li>Automatically close filled shapes when expanding clipped groups.</li>
<li>Fixed a bug in using the gradient popup view when editing the gradient.</li>
<li>Allow color picker use from the gradient popup views.</li>
<li>Show integer numbers with no decimals in the UI.</li>
<li>Separate default brush width from stroke width.</li>
<li>Added a brush size option to the context panel for the symbol set adjustment tools.</li>
<li>Fixed a bug in using width profile in image based brushes.</li>
<li>Fixed a bug expanding image based brushes.</li>
<li>Improved support for the wintab driver with non-Wacom tablet.</li>
<li>Show correct paper size with the Windows printer drivers.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/4653/update-1-2-040</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 11:23:08 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/4653.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 27 Sep 2024 18:46:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.2.040 on Sat, 28 Sep 2024 23:36:29 GMT]]></title><description><![CDATA[<p dir="auto">So much progress per update and already see a lot of things I need to try/recheck. It's nice to see that our bug reports matter. You're doing a really good job here, <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> (as always)</p>
]]></description><link>https://www.vectorstyler.com/forum/post/27182</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/27182</guid><dc:creator><![CDATA[debraspicher]]></dc:creator><pubDate>Sat, 28 Sep 2024 23:36:29 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.2.040 on Fri, 27 Sep 2024 19:55:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a></p>
<p dir="auto">Default Brush size is much better now <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=ec4d969cc53" class="not-responsive emoji emoji-android emoji--+1" style="height:23px;width:auto;vertical-align:middle" title=":+1:" alt="👍" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/27177</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/27177</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Fri, 27 Sep 2024 19:55:45 GMT</pubDate></item></channel></rss>
