<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Weird colour swatch behaviour]]></title><description><![CDATA[<p dir="auto"><em>Scenario 1</em></p>
<p dir="auto">Steps taken:</p>
<ol>
<li>Create a CMYK document using default colour settings or Global.</li>
<li>Create a Global swatch</li>
<li>Draw a rectangle and fill it with the newly created swatch</li>
<li>Convert document colour mode to RGB</li>
</ol>
<p dir="auto">Result:</p>
<ol>
<li>The fill colour disappears from the rectangle</li>
<li>The swatch disappears from the palette panel</li>
</ol>
<p dir="auto">Refer to attached screenshots.<br />
<img src="/forum/assets/uploads/files/1719004278476-new-swatch.png" alt="0_1719004250687_New swatch.png" class=" img-fluid img-markdown" /><br />
<em>New swatch.</em></p>
<p dir="auto"><img src="/forum/assets/uploads/files/1719005030058-rectangle.png" alt="0_1719005002433_Rectangle.png" class=" img-fluid img-markdown" /><br />
<em>Rectangle filled with new swatch.</em></p>
<p dir="auto"><img src="/forum/assets/uploads/files/1719005054104-swatch-disappears.png" alt="0_1719005027216_Swatch disappears.png" class=" img-fluid img-markdown" /><br />
<em>Swatch disappears after converting document to RGB.</em></p>
<p dir="auto"><img src="/forum/assets/uploads/files/1719005084455-fill-disappears-from-rectangle.png" alt="0_1719005057568_Fill disappears from rectangle.png" class=" img-fluid img-markdown" /><br />
<em>Fill disappears from rectangle after converting document to RGB.</em></p>
<p dir="auto"><img src="/forum/assets/uploads/files/1719004753732-panel.png" alt="0_1719004725207_panel.png" class=" img-fluid img-markdown" /><br />
<em>With the rectangle selected after RGB conversion,  the Colour panel shows the correct values for the Global colour albeit it displaying the wrong fill colour.</em></p>
<p dir="auto"><em>Scenario 2</em></p>
<ol>
<li>Duplicate the rectangle and cut the copy</li>
</ol>
<ol>
</ol>
<p dir="auto">Further steps:</p>
<ol>
<li>Now paste the previously cut rectangle</li>
</ol>
<ol>
<li>The fill colour reappears on original rectangle</li>
<li>The swatch also reappears in the palette panel</li>
</ol>
]]></description><link>https://www.vectorstyler.com/forum/topic/4412/weird-colour-swatch-behaviour</link><generator>RSS for Node</generator><lastBuildDate>Wed, 18 Nov 2026 09:05:51 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/4412.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 21 Jun 2024 21:27:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Weird colour swatch behaviour on Tue, 02 Jul 2024 14:14:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a>, thank you for the response.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26144</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26144</guid><dc:creator><![CDATA[William Kansepa]]></dc:creator><pubDate>Tue, 02 Jul 2024 14:14:53 GMT</pubDate></item><item><title><![CDATA[Reply to Weird colour swatch behaviour on Tue, 02 Jul 2024 06:32:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/william-kansepa" aria-label="Profile: William-Kansepa">@<bdi>William-Kansepa</bdi></a> I replicated this with one additional step, but it is not a bug (sort of).<br />
The one step needed (to make the color disappear) is to change the Palette field also in the Document Setup -&gt; Color section. This causes the creation of a new palette and the removal of the colors from the previous palette.</p>
<p dir="auto">If only the Color field is changed (to RGB), then it is all fine here.</p>
<p dir="auto">In case (2), it is similar, but when pasting the color is "re-imported".</p>
]]></description><link>https://www.vectorstyler.com/forum/post/26140</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/26140</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 02 Jul 2024 06:32:16 GMT</pubDate></item><item><title><![CDATA[Reply to Weird colour swatch behaviour on Mon, 24 Jun 2024 05:18:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/william-kansepa" aria-label="Profile: William-Kansepa">@<bdi>William-Kansepa</bdi></a> Got the file, I will try to replicate this.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/25952</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/25952</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 24 Jun 2024 05:18:27 GMT</pubDate></item><item><title><![CDATA[Reply to Weird colour swatch behaviour on Sun, 23 Jun 2024 10:57:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/25916">Weird colour swatch behaviour</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/william-kansepa" aria-label="Profile: William-Kansepa">@<bdi>William-Kansepa</bdi></a> I tried to replicate this using those steps, but here the swatch and fill both remained.</p>
<p dir="auto">Please send me a VS file with the first 3 steps done, so that is just needs to be converted to RGB. Did you use the Document Setup -&gt; Color to change to RGB mode?</p>
</blockquote>
<p dir="auto">Yes I did use the Document Setup -&gt; Color to change to RGB mode.<br />
I forgot to mention that the added swatch is from an Illustrator *.ASE palette imported into the Default Palette.</p>
<p dir="auto">I have sent the test files to your email.</p>
<p dir="auto">Edit PS: you can also try out Scenario 2 using the file that I send to you.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/25941</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/25941</guid><dc:creator><![CDATA[William Kansepa]]></dc:creator><pubDate>Sun, 23 Jun 2024 10:57:53 GMT</pubDate></item><item><title><![CDATA[Reply to Weird colour swatch behaviour on Sat, 22 Jun 2024 07:31:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/william-kansepa" aria-label="Profile: William-Kansepa">@<bdi>William-Kansepa</bdi></a> I tried to replicate this using those steps, but here the swatch and fill both remained.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/25916</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/25916</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sat, 22 Jun 2024 07:31:24 GMT</pubDate></item></channel></rss>
