<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Transparency via keyboard does not work (Windows .057)]]></title><description><![CDATA[<p dir="auto">I've seen this work once today, but not otherwise.</p>
<p dir="auto">I can't select an object on the canvas, and type 50 or 050 for 50% transparency. Nothing happens.</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/2372/transparency-via-keyboard-does-not-work-windows-057</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 11:09:03 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/2372.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 25 Aug 2022 19:34:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Transparency via keyboard does not work (Windows .057) on Tue, 03 Jan 2023 09:25:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/17073">Transparency via keyboard does not work (Windows .057)</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> This issue should be fixed in build 1.1.072</p>
</blockquote>
<p dir="auto">Yes, VS responds correctly to keyboard input now (tested on Windows 10 laptop) but the parser does not allow 0% - not even when 000 is entered.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/17101</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/17101</guid><dc:creator><![CDATA[Ingolf]]></dc:creator><pubDate>Tue, 03 Jan 2023 09:25:39 GMT</pubDate></item><item><title><![CDATA[Reply to Transparency via keyboard does not work (Windows .057) on Tue, 03 Jan 2023 06:30:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> This issue should be fixed in build 1.1.072</p>
]]></description><link>https://www.vectorstyler.com/forum/post/17073</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/17073</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 03 Jan 2023 06:30:22 GMT</pubDate></item><item><title><![CDATA[Reply to Transparency via keyboard does not work (Windows .057) on Fri, 14 Oct 2022 16:30:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/jayanta-das" aria-label="Profile: Jayanta-Das">@<bdi>Jayanta-Das</bdi></a> said in <a href="/forum/post/15244">Transparency via keyboard does not work (Windows .057)</a>:</p>
<blockquote>
<p dir="auto">when click two number:<br />
11-- transparency it set = 10<br />
23 -- transparency it set = 30 ( it takes the last digit and add suffix zero to it)</p>
</blockquote>
<p dir="auto">I keep this issue open.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/15253</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/15253</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 14 Oct 2022 16:30:43 GMT</pubDate></item><item><title><![CDATA[Reply to Transparency via keyboard does not work (Windows .057) on Fri, 14 Oct 2022 15:37:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> There is still some issue when I click:<br />
1-- transparency it set = 11<br />
2 -- transparency it set = 22<br />
3-- transparency it set = 33<br />
0-- transparency it set = 100 and so on.<br />
..................................................................................<br />
]]></description><link>https://www.vectorstyler.com/forum/post/15244</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/15244</guid><dc:creator><![CDATA[Jayanta Das]]></dc:creator><pubDate>Fri, 14 Oct 2022 15:37:38 GMT</pubDate></item><item><title><![CDATA[Reply to Transparency via keyboard does not work (Windows .057) on Fri, 14 Oct 2022 11:59:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ingolf" aria-label="Profile: Ingolf">@<bdi>Ingolf</bdi></a> This issue should be fixed in build 1.1.062</p>
]]></description><link>https://www.vectorstyler.com/forum/post/15195</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/15195</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 14 Oct 2022 11:59:31 GMT</pubDate></item><item><title><![CDATA[Reply to Transparency via keyboard does not work (Windows .057) on Fri, 26 Aug 2022 05:08:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ingolf" aria-label="Profile: Ingolf">@<bdi>Ingolf</bdi></a> said in <a href="/forum/post/13987">Transparency via keyboard does not work (Windows .057)</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">Does not work for the numeric keys on the right. Seems to be a bug.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13998</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13998</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 26 Aug 2022 05:08:33 GMT</pubDate></item><item><title><![CDATA[Reply to Transparency via keyboard does not work (Windows .057) on Thu, 25 Aug 2022 23:17:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a></p>
<p dir="auto">It doesn't work on my two Windows machines, one with Windows 10, the other with Windows 11.</p>
<p dir="auto">On the first (Windows 10)</p>
<li>I closed VS</li>
<li>Deleted (moved) C:\Users&lt;username&gt;\NumericPath</li>
<li>Restarted VS which now lacked license</li>
<li>Closed VS</li>
<li>Copied license.xml back to C:\Users&lt;username&gt;\NumericPath\vectorstyler1.0\vector\</li>
<li>Started VS and was now in default config</li>
<p dir="auto">Still not working. I would think that all custom config is taken out of the equation now.</p>
<p dir="auto">It doesn't work on my Windows 11 machine either. Both machines have one thing in common and that is that they use external wireless keyboard with USB receiver. But it doesn't work on numeric keys or regular keys.</p>
<p dir="auto">It still works perfectly on my Mac.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13993</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13993</guid><dc:creator><![CDATA[Ingolf]]></dc:creator><pubDate>Thu, 25 Aug 2022 23:17:42 GMT</pubDate></item><item><title><![CDATA[Reply to Transparency via keyboard does not work (Windows .057) on Thu, 25 Aug 2022 19:54:30 GMT]]></title><description><![CDATA[<p dir="auto">Strange shit. I purged the entire user folder and restored just the license file, but still nothing.</p>
<p dir="auto">Allright thanks, I'll see later on my Mac and Windows 11 machine.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13992</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13992</guid><dc:creator><![CDATA[Ingolf]]></dc:creator><pubDate>Thu, 25 Aug 2022 19:54:30 GMT</pubDate></item><item><title><![CDATA[Reply to Transparency via keyboard does not work (Windows .057) on Thu, 25 Aug 2022 19:48:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ingolf" aria-label="Profile: Ingolf">@<bdi>Ingolf</bdi></a></p>
<p dir="auto">works here also<br />
win 10 / VS 1.1.57</p>
<p dir="auto">i did select an object and type 30<br />
and other Values</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13991</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13991</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Thu, 25 Aug 2022 19:48:02 GMT</pubDate></item><item><title><![CDATA[Reply to Transparency via keyboard does not work (Windows .057) on Thu, 25 Aug 2022 19:38:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ingolf" aria-label="Profile: Ingolf">@<bdi>Ingolf</bdi></a>  tested on my M1 Mac and works fine here</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13989</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13989</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Thu, 25 Aug 2022 19:38:08 GMT</pubDate></item></channel></rss>
