<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Corner Editing Nodes shifting position after scaling]]></title><description><![CDATA[<p dir="auto">If you have Transformed Stroke or Uniformed Stroke Scaling selected, the Corner Editing Nodes will shift position when you disproportionately stretch object sideways or upward/downward. This distorts the corners when applying Corner effects.</p>
<p dir="auto">Note that this shift only occurs when there is a Stroke present. If the artwork/object only has a fill, this distortion doesn't take place.</p>
<p dir="auto">Issue is still present in VS 1.4</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5986/corner-editing-nodes-shifting-position-after-scaling</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 23:14:32 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5986.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 22 Nov 2026 10:50:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Corner Editing Nodes shifting position after scaling on Sun, 22 Nov 2026 13:01:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/william-kansepa" aria-label="Profile: William-Kansepa">@<bdi>William-Kansepa</bdi></a> I will check earlier versions, but unless "Direct Shape Transform" is enabled, this difference exists</p>
]]></description><link>https://www.vectorstyler.com/forum/post/34467</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/34467</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sun, 22 Nov 2026 13:01:32 GMT</pubDate></item><item><title><![CDATA[Reply to Corner Editing Nodes shifting position after scaling on Sun, 22 Nov 2026 12:59:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/34465">Corner Editing Nodes shifting position after scaling</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/william-kansepa" aria-label="Profile: William-Kansepa">@<bdi>William-Kansepa</bdi></a> This is by design and it is the consequence of the Transformed Stroke option (but can be other cause also):<br />
If you add any shape effect to an object, the shape corner is added before the effect.<br />
In this case the "Transformed Stroke" option causes a "Transform" shape effect to be added.</p>
<p dir="auto">If there are no shape effects, the scaling tool will just adjust the width/height of the rectangle. Which does not add a shape effect.</p>
</blockquote>
<p dir="auto">Thank you <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: vectorstyler">@<bdi>vectorstyler</bdi></a>, but this never used to be the case in version 1.2 and earlier versions of 1.3 with both options enabled... What changed?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/34466</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/34466</guid><dc:creator><![CDATA[William Kansepa]]></dc:creator><pubDate>Sun, 22 Nov 2026 12:59:35 GMT</pubDate></item><item><title><![CDATA[Reply to Corner Editing Nodes shifting position after scaling on Sun, 22 Nov 2026 10:54:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/william-kansepa" aria-label="Profile: William-Kansepa">@<bdi>William-Kansepa</bdi></a> This is by design and it is the consequence of the Transformed Stroke option (but can be other cause also):<br />
]]></description><link>https://www.vectorstyler.com/forum/post/34465</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/34465</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sun, 22 Nov 2026 10:54:35 GMT</pubDate></item></channel></rss>
