<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.3.024]]></title><description><![CDATA[<h3>VectorStyler 1.3.024 release notes</h3>
<li>Fixed a bug in merging with objects containing multiple fills</li>
<li>Fixed a bug in text on path line spacing</li>
<li>Fixed a bug in composite shape groups</li>
<li>Fixed a bug in importing composite shape groups from Illustrator files</li>
<li>Fixed a bug in positioning with Paste Inside</li>
<li>Fixed a bug in kerning when the extended text shaping mode is active</li>
<li>Fixed a bug in merging shapes inside transformed layers</li>
<li>Fixed a editing redraw issue inside clipped group</li>
<li>Allow Shift+ deselection when Shape or Point snapping is enabled</li>
<li>Expanding stroke should set the fill overprint to the same as the stroke overprint</li>
<li>Snap to Member Objects to be disabled by default</li>
<li>Adjusted two default arrow preset positions</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/5902/update-1.3.024</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 22:33:50 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5902.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 17 Aug 2026 04:56:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.3.024 on Mon, 17 Aug 2026 17:14:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Thank you for the update! I will test it out and get back to you if I have any further issues with those specific fixes.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33844</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33844</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Mon, 17 Aug 2026 17:14:29 GMT</pubDate></item></channel></rss>
