<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Merge operation deletes the object underneath]]></title><description><![CDATA[<p dir="auto"><img src="/forum/assets/uploads/files/1786470983547-ff4dcb78-a205-445e-934f-f983b76affad-cleanshot-2026-08-11-at-13.54.18.png" alt="ff4dcb78-a205-445e-934f-f983b76affad-CleanShot 2026-08-11 at 13.54.18.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I’m having an issue with the Merge boolean operation.</p>
<p dir="auto">When I place one object over another and use Merge, the object underneath, which should have the overlapping area cut out of it, seems to have deleted completely instead.</p>
<p dir="auto">I first noticed this in my normal setup, so I reset VectorStyler to the default settings and tried the same operation again. The same issue still occurs.</p>
<p dir="auto">Steps to reproduce<br />
Create two overlapping objects.<br />
Place the object that will be used for the cut above the other object.<br />
Select both objects.<br />
Apply Merge.<br />
The lower object is deleted instead of remaining with the overlapping area removed.</p>
<p dir="auto">I’ve attached an example file that reproduces the problem.<br />
<a href="/forum/assets/uploads/files/1786471897809-merge-issue-with-flames.vstyler">Merge Issue with Flames.vstyler</a></p>
<p dir="auto">Here's my OS I'm working on,</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1786471838399-7ccf3480-234e-4c85-9543-a8b79c05f9c5-cleanshot-2026-08-11-at-13.39.56.png" alt="7ccf3480-234e-4c85-9543-a8b79c05f9c5-CleanShot 2026-08-11 at 13.39.56.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Is anyone else seeing this behavior, or is there something about the Merge operation that I’m missing?</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5899/merge-operation-deletes-the-object-underneath</link><generator>RSS for Node</generator><lastBuildDate>Tue, 11 Aug 2026 20:09:10 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5899.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 11 Aug 2026 18:00:02 GMT</pubDate><ttl>60</ttl></channel></rss>
