<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Raster image flashes while dragging nodes at reduced opacity]]></title><description><![CDATA[<p dir="auto">I am seeing a display issue when manually tracing over a raster image.<br />
Here is the VS file for reference:<br />
<a href="/forum/assets/uploads/files/1784642208763-background-flashing-while-editing-vector.vstyler">Background flashing while editing vector.vstyler</a></p>
<p dir="auto">When the raster image is set below 100% opacity, it begins flashing or flickering while I drag nodes on a vector shape with the Node Tool.</p>
<p dir="auto">The issue does not occur in either of these situations:</p>
<li>The raster image is set to 100% opacity.</li>
<li>A vector shape is added inside the same layer as the raster image.</li>
<p dir="auto"><a href="https://cleanshot.com/share/22ZJ4l0h" rel="nofollow ugc">In this video, I first demonstrate the flashing while editing the vector path over the reduced-opacity raster image.</a> I then add a vector shape with reduced opacity to the raster image layer, and the flashing stops.</p>
<p dir="auto">Steps to reproduce</p>
<ol>
<li>Place a raster image in the document.</li>
<li>Reduce the opacity of the raster layer.</li>
<li>Create a vector shape in a new layer above the image layer.</li>
<li>Use the Node Tool to drag nodes on the vector shape.</li>
<li>The raster image flashes while the nodes are being moved.</li>
</ol>
<p dir="auto">Adding a vector shape to the raster image layer appears to prevent the flashing.</p>
<p dir="auto">Has anyone else seen this issue, or is there a display or rendering setting that could be causing it?</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5874/raster-image-flashes-while-dragging-nodes-at-reduced-opacity</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 20:53:15 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5874.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 21 Jul 2026 13:55:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Raster image flashes while dragging nodes at reduced opacity on Tue, 21 Jul 2026 17:43:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ridgehammer" aria-label="Profile: Ridgehammer">@<bdi>Ridgehammer</bdi></a> I opened a bug on this and will try to fix it.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33699</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33699</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 21 Jul 2026 17:43:41 GMT</pubDate></item></channel></rss>
