<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Click Through Object Selection and Select Next]]></title><description><![CDATA[<p dir="auto">I prefer selecting objects on the Artboard rather than using expanded Layers.<br />
Attempting to "<strong>drill down</strong>" through a stack of objects <strong>left-clicking repeatedly</strong> on the same location, I find that</p>
<li>
<p dir="auto">a <strong>looong pause</strong> is needed between clicks, to get to the bottommost object.<br />
If successive clicks are fast, like doubleclicks, the ClickThrough function goes inactive. (Double Click/No Key setting is set to Nothing)<br />
Could another setting be hampering me here?</p>
</li>
<li>
<p dir="auto">Click Through will only drill down to objects on the <strong>same Layer</strong>. Is that intentional?<br />
I would assume it should select all the way down though visible, unlocked objects, regardless of layers?</p>
</li>
<li>
<p dir="auto"><strong>Select Next</strong> is sort of the same thing, but a menu selection or keyboard action is needed.<br />
Contrary to Click Through action, Select Next <strong>traverses Layers</strong>.<br />
But Select Next picks <strong>upward</strong> from the bottom, instead of <strong>drilling down</strong> from a visual point of view. Probably stack sequence related.</p>
</li>
<p dir="auto">Any tips or experience here that can help me machine-gunning my way down multi layered overlapping artwork?<br />
Or is Click Through Selection buggy?</p>
<p dir="auto">BR/ Lars Herold<br />
1.3.021 Win</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1784639905957-click_through.png" alt="Click_Through.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5873/click-through-object-selection-and-select-next</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 21:28:09 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5873.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 21 Jul 2026 13:54:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Click Through Object Selection and Select Next on Tue, 21 Jul 2026 17:42:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/larsherold" aria-label="Profile: larsherold">@<bdi>larsherold</bdi></a> said in <a href="/forum/post/33692">Click Through Object Selection and Select Next</a>:</p>
<blockquote>
<li>a <strong>looong pause</strong> is needed between clicks, to get to the bottommost object.<br />
Could another setting be hampering me here?</li>
</blockquote>
<p dir="auto">No other settings, the problem is that if it detects a double click it will not do the selection.<br />
I will try to find a way to solve this</p>
<blockquote>
<li>Click Through will only drill down to objects on the <strong>same Layer</strong>. Is that intentional?</li>
</blockquote>
<p dir="auto">Yes. I opened a bug on this</p>
<blockquote>
<li><strong>Select Next</strong> is sort of the same thing, but a menu selection or keyboard action is needed.</li>
</blockquote>
<p dir="auto">There is Select Previous also.</p>
<blockquote>
<p dir="auto">Or is Click Through Selection buggy?</p>
</blockquote>
<p dir="auto">Not buggy, just cannot work with double clicks. I will try to find a solution for this</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33698</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33698</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 21 Jul 2026 17:42:57 GMT</pubDate></item></channel></rss>
