<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PDF export does not preserve stroke opacity (VS 1.3)]]></title><description><![CDATA[<p dir="auto">Version: VectorStyler <a href="http://1.3.xxx" rel="nofollow ugc">1.3.xxx</a> (please insert exact build)</p>
<p dir="auto">Description</p>
<p dir="auto">When exporting a document to PDF using the default File → Export → PDF settings, the opacity of a stroked path is not preserved.</p>
<p dir="auto">The transparency of filled objects is exported correctly, but the connecting line segment (stroke) is rendered fully opaque.</p>
<p dir="auto">Steps to Reproduce</p>
<p dir="auto">Create a stroked path with opacity less than 100%.<br />
Include other objects (e.g., filled circles or an arrowhead) using the same opacity.<br />
Export using File → Export → PDF with the default settings.<br />
Open the exported PDF in Preview (or another PDF viewer).</p>
<p dir="auto">Expected Result</p>
<p dir="auto">All objects, including stroked paths, retain their assigned opacity.</p>
<p dir="auto">Actual Result</p>
<p dir="auto">Filled objects preserve their transparency correctly.<br />
The stroked line segment is rendered fully opaque.</p>
<p dir="auto">This suggests that stroke opacity is not being written correctly during PDF export, while fill opacity is preserved.</p>
<p dir="auto">Attachments</p>
<p dir="auto">Original VectorStyler document.<br />
Exported PDF.<br />
Screenshot of the original VectorStyler rendering showing the intended appearance.</p>
<p dir="auto">Notes</p>
<p dir="auto">Export performed using the default File → Export → PDF settings.<br />
The issue appears specific to the stroke; other transparent objects in the same document export correctly.<img src="/forum/assets/uploads/files/1784054499274-screenshot-2026-07-14-at-2.22.49-pm.png" alt="Screenshot 2026-07-14 at 2.22.49 PM.png" class=" img-fluid img-markdown" /> <a href="/forum/assets/uploads/files/1784054504352-dest.pdf">Dest.pdf</a> <a href="/forum/assets/uploads/files/1784054510808-source.vstyler">Source.vstyler</a></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5860/pdf-export-does-not-preserve-stroke-opacity-vs-1.3</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 14:16:29 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5860.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 14 Jul 2026 18:42:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PDF export does not preserve stroke opacity (VS 1.3) on Wed, 15 Jul 2026 07:30:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/jpsimmons" aria-label="Profile: jpsimmons">@<bdi>jpsimmons</bdi></a> I opened a bug on this and will try to fixit.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33634</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33634</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 15 Jul 2026 07:30:46 GMT</pubDate></item></channel></rss>
