<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Some basics regarding the creation and use of artistic brushes, as well as a fast way for selecting such a brush.]]></title><description><![CDATA[<p dir="auto">This little Tut will show some Basics, around how to create a Artistic Brush in Vectorstyler.</p>
<p dir="auto">It consists of three parts.<br />
This part, the first part shows how to create and save an Artistic Brush.<br />
The second part covers where to find, select, and—if necessary—delete the Artistic Brush you have created.<br />
The third part shows a very fast way to select and use an Artistic Brush.</p>
<p dir="auto"><strong>First Part:</strong><br />
<strong>How to create a Artistic Brush the Basics</strong></p>
<p dir="auto">Made a Shape for a new Brush by combining two existes Brushes (Boolean Union)<br />
<img src="/forum/assets/uploads/files/1783060517004-new-artistic-brush.png" alt="new-artistic brush.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Select the Shape and choose<br />
Menu &gt; Styles &gt; Create Styles &gt; Create Artistic Brush Preset</p>
<p dir="auto">If you unsure about using Style or Preset, choose Preset<br />
A Style would work with a Document<br />
A Preset work with all Documents</p>
<p dir="auto">A Panel appaers give your Brush a name and set “Tint” to “Solid”<br />
This allows to change the color of a Artistic Brush.</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1783060657682-my-brush.png" alt="my brush.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5850/some-basics-regarding-the-creation-and-use-of-artistic-brushes-as-well-as-a-fast-way-for-selecting-such-a-brush.</link><generator>RSS for Node</generator><lastBuildDate>Fri, 03 Jul 2026 09:01:05 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5850.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Jul 2026 06:37:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Some basics regarding the creation and use of artistic brushes, as well as a fast way for selecting such a brush. on Fri, 03 Jul 2026 07:41:02 GMT]]></title><description><![CDATA[<p dir="auto">Great foundational tutorial! Thanks for sharing.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33576</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33576</guid><dc:creator><![CDATA[Li Xiao]]></dc:creator><pubDate>Fri, 03 Jul 2026 07:41:02 GMT</pubDate></item><item><title><![CDATA[Reply to Some basics regarding the creation and use of artistic brushes, as well as a fast way for selecting such a brush. on Fri, 03 Jul 2026 07:18:05 GMT]]></title><description><![CDATA[<p dir="auto"><strong>Part Three:<br />
A special and fast way to select an Artistic Brush</strong><br />
.<br />
.<br />
<img src="/forum/assets/uploads/files/1783062036703-style-picker-small.png" alt="style picker-small.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">.<br />
.</p>
<p dir="auto">To show you how you can use this Feature for fast Brush selecting<br />
do the following:</p>
<p dir="auto">Draw your most used Artistic Brushes at a Side.</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1783062143662-brushes-aside-small.png" alt="brushes aside-small.png" class=" img-fluid img-markdown" /><br />
.<br />
.<br />
Select a Brush with the Transform Tool<br />
then select the Brush Tool and draw a Brush stroke with it<br />
.<br />
<img src="/forum/assets/uploads/files/1783062216612-draw-a-stroke.png" alt="draw a stroke.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">While the Brush Tool and the new created Brush Stroke is still selected<br />
hold the Ctrl key (PC) down.</p>
<p dir="auto">You see the Nodes then and your Mouse pointer switch to a triangle.</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1783062324838-you-see-the-nodes-then.png" alt="you see the nodes then.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Now, hover your mouse cursor over another brush stroke. Its nodes should<br />
then appear. Simply click on one of these Node.</p>
<p dir="auto">Clicking on a node is the surest way to select the brush's properties.<br />
Clicking the path works too, but a node is easier to hit.</p>
<p dir="auto">Since the Style Picker remains active while you hold down the Ctrl key, the properties<br />
of that brush stroke will be applied and will be used when you draw your next Brush Stroke.</p>
<p dir="auto">Now release the Ctrl key, which returns you to the Brush tool, and draw a brush stroke.<br />
And you can see that you are now drawing with the properties of this brush.</p>
<p dir="auto">This is the fastest method I know in VectorStyler for switching between brushes.</p>
<p dir="auto">By the way, you don't have to place the brushes next to your artwork.<br />
However, it might be helpful. You can also simply paint, change colors, and then use<br />
the method described to switch back to the brush you want to use.</p>
<p dir="auto">That's it – have fun painting with Vectorstylers Artistic Brushes.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33573</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33573</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Fri, 03 Jul 2026 07:18:05 GMT</pubDate></item><item><title><![CDATA[Reply to Some basics regarding the creation and use of artistic brushes, as well as a fast way for selecting such a brush. on Fri, 03 Jul 2026 06:58:15 GMT]]></title><description><![CDATA[<p dir="auto"><strong>Part two:</strong><br />
<strong>Where to find a new created Artistic Brush and how to delete a Artistic Brush preset</strong></p>
<p dir="auto">Usually you find a new Artistic Brush down below at the Brush drop down menu</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1783061252410-my-brush2.png" alt="my brush2.png" class=" img-fluid img-markdown" /><br />
.<br />
.<br />
.<br />
Calling the Brush Preset Panel are a way which may a bit more comfortable for selecting an Artistic Brush.</p>
<p dir="auto">For this go to<br />
Menu &gt; Window &gt; Presets &gt; Brush Presets<br />
which opens the Brush Presets Panel</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1783061705673-my-brush3.png" alt="my Brush3.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">This Panel is also helpful if you like to delete a Brush Preset<br />
Select the Brush and press "Remove the selected Presets"</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33572</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33572</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Fri, 03 Jul 2026 06:58:15 GMT</pubDate></item></channel></rss>
