<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[the following applications are using files which the installer must update (failed several times)]]></title><description><![CDATA[<p dir="auto"><img src="/forum/assets/uploads/files/1783014971006-4c92c041-8208-41aa-ae19-d99d29de2b53-image.png" alt="4c92c041-8208-41aa-ae19-d99d29de2b53-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5846/the-following-applications-are-using-files-which-the-installer-must-update-failed-several-times</link><generator>RSS for Node</generator><lastBuildDate>Fri, 03 Jul 2026 08:58:47 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5846.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 02 Jul 2026 17:56:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to the following applications are using files which the installer must update (failed several times) on Thu, 02 Jul 2026 18:25:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/clippy-notes" aria-label="Profile: Clippy-notes">@<bdi>Clippy-notes</bdi></a> Yes, if it is running in the background this will cause this.<br />
It should not run if the window is closed</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33563</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33563</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Thu, 02 Jul 2026 18:25:21 GMT</pubDate></item><item><title><![CDATA[Reply to the following applications are using files which the installer must update (failed several times) on Thu, 02 Jul 2026 17:59:30 GMT]]></title><description><![CDATA[<p dir="auto">Solution: The installer couldn't update the files because VectorStyler was still running in the background, even though the application window was closed.</p>
<p dir="auto">Fix:</p>
<p dir="auto">Open Task Manager (Ctrl + Shift + Esc).<br />
Find VectorStyler.exe under the Processes tab.<br />
Right-click it and select End Task.<br />
Go back to the installer and click Try Again.</p>
<p dir="auto">After ending the background process, the installation completed successfully. Using Continue wasn't necessary and avoids having files replaced only after a reboot.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33562</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33562</guid><dc:creator><![CDATA[Clippy notes]]></dc:creator><pubDate>Thu, 02 Jul 2026 17:59:30 GMT</pubDate></item></channel></rss>
