Preview
The retail version has been released.
Please implement the preview function.
VS 1.x cannot preview icons.
It is very inconvenient that you cannot check the contents without opening the file.Are there any plans for browsing features in the future?
Even if it's impossible to implement browsing, I'd appreciate it if you can see it in the Finder.
@861475_VctSt A quick look plugin for Finder is in the plan.
@vectoradmin
It's "VS.ql generator".
I look forward to the realization as soon as possible.
@vectoradmin
Thank you very much for your wide range of support.
I have quite a few more VS icons on my Mac.
I am having a hard time identifying the subtle differences in versions of my work.
I often have to open several documents and compare them. I'm sure you users are doing the same.
This is my sincere hope. I would like to be able to preview my work as soon as possible.
@861475_VctSt I will prioritize this, but it may take some time.
@vectoradmin
VS 1.1.001
Mac OS 10.15.7Thanks for adding Quicklook.
However, Quicklook does not work.To test it, I took it out and put it in a given directory. Still it does not work.
/Users/hara/Library/QuickLook/QuickLook.qlgenerator
@861475_VctSt It's working over here for me.
Did you turn on "store preview" ahead of time?
If you're opening files created prior to beta build 1.1, it's not going to work because preview images were not created for those files at that time. You also need to go into Document Setup and click the box for "Store Preview" so that a preview is created and saved with that specific file. If you set it in "new Document Setup" it will auto create a preview with each new file you make going forward.
I don't know if going back to the old files and saving with "store preview" turned on would create a new preview for those or not - have not tried it yet.
Thanks.
However, the progress indicator spins around but eventually shows the VS icon.Is there anything else I need to set other than
Document Setup>General>Store Preview?
@861475_VctSt What is your Mac setup?
@vectoradmin
MacBook Air (13-inch, Mid 2012)
8 GB 1600 MHz DDR3
Dual-Core Intel Core i5
1.8 GHzMac OS 10.15.17
The above is the main machine.
The others are stored away and not in use.
@vectoradmin
MacBookPro(Retina, 15inch)
Mac OS 10.14.6I tried it here as well. It doesn't even turn on the progress indicator, it just shows the VS icon.
@vectoradmin Same here:
MacBook Pro (15-inch, 2016) running macOS 12.1 (Monterey)
Four-core 2,7 GHz Intel Core i7
Radeon Pro 455 2 GB
16 GB 2133 MHz LPDDR3
@vectoradmin
v1.1.016
I can't see it yet in my environment.
@861475_VctSt There are still problems with preview on some MacOS versions, this is an open issue.
@vectoradmin
All right, all right.
I'll wait patiently.
@VectorStyler I was going to ask the same question. Is it planned to be able to preview VS files soon (in Windows)? It is in fact impossible to preview these files in another app and there is no such facility in VS (yet). Thanks
There are some issues with the Mac previewing, but the Windows preview should work now.
Of course you must enable select a previewing mode in the document setup and save the file with the preview (beta 1.2).
@VectorStyler Did not notice this feature in 1.2. I can preview an image with a red background in a third-party app but not in File Explorer or ABridge.
@VectorStyler Thanks Here is what I can see in XnView (red background):
