<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[TEXT enveloppe deform]]></title><description><![CDATA[<p dir="auto">Hello</p>
<p dir="auto">Is there a way on VectorStyler to deform a text according to a vector shape (see illustrator capture)?<img src="/forum/assets/uploads/files/1778784393744-thinktank-2026-05-14-%C3%A0-20.38.45.png" alt="THINKTANK 2026-05-14 à 20.38.45.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5792/text-enveloppe-deform</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 13:45:40 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5792.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 14 May 2026 18:46:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to TEXT enveloppe deform on Thu, 14 May 2026 20:45:50 GMT]]></title><description><![CDATA[<p dir="auto">Thanks it's work fine</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33315</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33315</guid><dc:creator><![CDATA[ZATOPEK]]></dc:creator><pubDate>Thu, 14 May 2026 20:45:50 GMT</pubDate></item><item><title><![CDATA[Reply to TEXT enveloppe deform on Thu, 14 May 2026 19:43:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/zatopek" aria-label="Profile: ZATOPEK">@<bdi>ZATOPEK</bdi></a> Yes:</p>
<li>Create the text (the two words must be separated and resized to the same width)</li>
<li>Add an Envelope effect from the Shape Effects panel</li>
<li>Draw a circle and select both the text and circle</li>
<li>In the Shape Effects panel menu select Pick Shape</li>
<li>Open the Envelope options and uncheck Envelope (there might be a bug here and this is not applied, so you need to press Enter in the smoothness field for example)</li>
<li>Activate the effect editor (panel bottom, second button)</li>
<li>Insert new mesh point with double click</li>
<li>Adjust the mesh shape to get the internal waving</li>
]]></description><link>https://www.vectorstyler.com/forum/post/33311</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33311</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Thu, 14 May 2026 19:43:35 GMT</pubDate></item></channel></rss>
