<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Number key opacity shortcuts broken]]></title><description><![CDATA[<p dir="auto">After updating to 1.3.017 the number keys no longer change object opacity.</p>
<p dir="auto">Previously, pressing 1–9 changed opacity to 10–90%, and 0 set it to 100%. After the update, pressing 6 triggers “View Using GPU” instead. In Application Shortcuts, I also saw several number keys assigned to “Unknown Command” and 8 assigned to “Premultiplied”.<br />
I reverted to the previous version and the opacity shortcuts work normally again. I don’t see this shortcut change mentioned in the 1.3.017 release notes, so it may be a shortcut migration regression.</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5782/number-key-opacity-shortcuts-broken</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 18:57:16 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5782.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 May 2026 15:06:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Number key opacity shortcuts broken on Mon, 11 May 2026 17:44:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a>  Thank you so much.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33262</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33262</guid><dc:creator><![CDATA[Honor]]></dc:creator><pubDate>Mon, 11 May 2026 17:44:32 GMT</pubDate></item><item><title><![CDATA[Reply to Number key opacity shortcuts broken on Mon, 11 May 2026 16:48:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> thank you! would you mind adding a post telling us it's been updated (if you don't need to do so with a new version increment)?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33257</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33257</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Mon, 11 May 2026 16:48:46 GMT</pubDate></item><item><title><![CDATA[Reply to Number key opacity shortcuts broken on Mon, 11 May 2026 15:45:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/honor" aria-label="Profile: Honor">@<bdi>Honor</bdi></a> I will try to upload today a fix, but without version increment (if possible)</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33256</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33256</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 11 May 2026 15:45:56 GMT</pubDate></item><item><title><![CDATA[Reply to Number key opacity shortcuts broken on Mon, 11 May 2026 15:16:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a>  Thanks for the quick reply. I’ll wait for the fix update with the debugging shortcuts removed.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33255</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33255</guid><dc:creator><![CDATA[Honor]]></dc:creator><pubDate>Mon, 11 May 2026 15:16:55 GMT</pubDate></item><item><title><![CDATA[Reply to Number key opacity shortcuts broken on Mon, 11 May 2026 15:07:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/honor" aria-label="Profile: Honor">@<bdi>Honor</bdi></a> <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61e.png?v=ec4d969cc53" class="not-responsive emoji emoji-android emoji--disappointed" style="height:23px;width:auto;vertical-align:middle" title=":(" alt="😞" /> Forgot some debugging shortcuts in the build</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33254</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33254</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 11 May 2026 15:07:27 GMT</pubDate></item></channel></rss>
