<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Copy paste between VS and other applications]]></title><description><![CDATA[<p dir="auto">I’m using VS and Affinity together and often copy vector elements from Affinity into VS to make adjustments.</p>
<p dir="auto">When I paste them back from VS into Affinity, the vectors come in at a smaller size than the originals. I then have to manually reposition and scale them to match their original placement.</p>
<p dir="auto">I’ve tested this with documents set to the same pixel dimensions in both applications and tried copying objects from VS as both SVG and PDF.</p>
<p dir="auto">However, I haven’t been able to preserve the original size. (Maintaining position is even more difficult, as pasted elements are centered by default.)<br />
I’ve attached sample documents from both applications for reference.<br />
<a href="/forum/assets/uploads/files/1778506626658-958f23f3-57dd-4887-a129-30707f342034-vs-affinity-copy-paste.zip">958f23f3-57dd-4887-a129-30707f342034-VS Affinity copy paste.zip</a> VS Affinity copy paste.zip</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/5781/copy-paste-between-vs-and-other-applications</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 18:57:19 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5781.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 May 2026 13:37:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Copy paste between VS and other applications on Mon, 11 May 2026 13:48:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ericp" aria-label="Profile: EricP">@<bdi>EricP</bdi></a> I added this to the backlog as a bug</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33252</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33252</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 11 May 2026 13:48:10 GMT</pubDate></item></channel></rss>
