<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.3.017]]></title><description><![CDATA[<h3>VectorStyler 1.3.017 release notes</h3>
<li>Fixed a bug in the Separate Path action, and the path eraser tool</li>
<li>Fixed a bug causing snapping to ghost shapes</li>
<li>Fixed an issue causing freeze with GPU compute</li>
<li>Export DXF coordinates in the selected units</li>
<li>Show a default color for empty color in panels</li>
<li>Fixed a bug in repeater region proportional mode</li>
<li>Added an overprint export option to PDF/X</li>
<li>Export Again to use current document name</li>
<li>Open file panel to start from current document folder</li>
<li>Fixed a PDF importing issue</li>
<li>Fixed a bug in editing stroke profiles inside transformed layers</li>
<li>Fixed a bug in deleting in the Layers panel while the stroke profile tool is active</li>
<li>Selecting alternate glyph should disable OpenType features</li>
<li>Fixed an issue in selecting corner size from the Corner panel while the Node tool is active</li>
<li>Changing path node to smooth should adjust selected control point position</li>
<li>Fixed a bug in selecting blend mode for the channels of separation halftones</li>
<li>Added an option to complete drawing with right mouse click</li>
<li>Fixed a regression in transparency rendering</li>
<li>Editing transparency mask inside transformed objects</li>
<li>Update gradient position number in panel when gradient stop is selected</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/5780/update-1.3.017</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 18:56:29 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5780.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 May 2026 07:35:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.3.017 on Mon, 11 May 2026 17:15:34 GMT]]></title><description><![CDATA[<p dir="auto">Uploaded a fix to the opacity shortcut issue.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33259</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33259</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 11 May 2026 17:15:34 GMT</pubDate></item></channel></rss>
